Clublog no longer shows QSOs on my QRZ page
Discussion in 'Community Help Center' started by VE3VEE, Jul 8, 2015.
  1. N6QIC
    N6QIC Ham Member QRZ Page
    I have reported it to an Administrator and other QRZ Staff in post #9. Please be patient, I am sure they are looking into the issues that you are all having.
    You can open a support ticket hear: https://forums.qrz.com/support
  2. VE3VEE
    VE3VEE XML Subscriber QRZ Page
    It seems they are working on it. Now one can access both, the http and https, versions of this site. Earlier in the morning we all had this problem because we were all being redirected to the https version.
    As long as were are not being forced to the https version, we can even get away with the embedding of non-https content. However, if QRZ.com is intent on eventually switching to https, then there will have to be a slight change in the code for the embedding of the content hosted at other servers and the content also will need to be https.
    73 Marvin VE3VEE
  3. M0TTB
    M0TTB Ham Member QRZ Page
    seems all sorted now :)
    Well done techs.
  4. K8BZ
    K8BZ Ham Member QRZ Page
    Same problem occurred here at the same time Marvin. I reloaded the source code a few times trying to fix the problem but no luck. I'm using Google Chrome for browser here but also tried Internet Explorer with same result. When I searched your call I could see your listing of last 30 qso's but when I did a qso search it did not display anything at all, The list of 30 last qso's went away too.
    Run my call and let me know if it displays the last 10 qso's for you. Thanks, Steve, K8BZ
  5. VE3VEE
    Hi Steve,
    Good observation about the Clublog search feature. It doesn't seem to work at the present time when we are accessing the https version of the QRZ bio page.
    At this moment, QRZ.com lets us access two versions of our bio pages, http and https version of the same. For example you bio page:
    - http://www.qrz.com/db/k8bz
    - https://www.qrz.com/db/k8bz
    The http version seems fully functional and all works as expected.
    The https version of the page for most users currently does not display Clublog, unless you've made the earlier mentioned small change to the source URL. If you made the small modification, the clublog is visible just fine, but its search function doesn't work.
    I see that you've made the modification to the code so the Clublog is visible on your page in both, http & https versions. You can use the search feature just fine in your http version. The search is not working in your https version, but at least your Clublog is visible.
    73 Marvin VE3VEE
  6. K8BZ
    Thanks for the info Marvin. QRZ.com appears to be down right now. Can't access either version at this time. Hopefully it because they are making corrections. I get OQRS qsl requests at times and it's really the only reason I keep it on my QRZ page, so I hope they can get it resolved. When the problem first came up I kept doing searches for "Club Log QRZ.com problem" and didn't get any possible responses until today when your thread showed up. So I was relieved to see it wasn't just me and that it will probably be resolved. Thanks for getting things started. 73 Steve, K8BZ
  7. AA7BQ
    AA7BQ QRZ Founder Administrator QRZ Page
