cleaning roller inductor to nye viking mb v a
Discussion in 'General Technical Questions and Answers' started by W7LTF, Dec 8, 2019.
  1. K7TRF
    I'll use it sparingly on some circuitry like cleaning pots used in solid state gear where working impedances are relatively low. I've cleaned up way too many Deoxit messes on old tube gear where folks sprayed it all over and created leakage paths near tube sockets and high impedance tube circuitry causing all kinds of strange problems. I won't use the stuff at all near high voltage or high power circuitry and that includes things like band switches associated with a tube final stage or cleaning parts in an antenna tuner like roller inductors.
    It's not terrible when used sparingly for some work, mostly scratchy pots in solid state gear but it can cause a lot of trouble if not applied well or when applied in the wrong places like switches that see HV or relatively high power.
  2. N8ZL
    N8ZL Ham Member QRZ Page
    I have use erasers on all kinds of contacts for more than 5 decades. works great.
    NE4EB likes this.
  3. N8FVJ
    N8FVJ Ham Member QRZ Page
    I use DeOxit to clean my HO train brass track. One quick wipe and it is like new. Should not leave any residue on the inductor as it does not on the brass track.
    K8AI and WA6SW like this.
  4. NN6D
    NN6D Ham Member QRZ Page
    well, I'm not a chemist and I imagine there are erasers made with different ingredients these days but I have seen a copper piece cleaned with an eraser that turned green in those spots, I also used an eraser once on circuit board traces and it was very hard to solder to afterwards even after cleaning with acetone so at least test your eraser first.
    never used de-oxit and corrosion-X is my preferred magic cure
  5. K8AI
    K8AI Ham Member QRZ Page
    Where did you find Deoxit contains oxalic acid? I can't seem to find that tidbit of info.
  6. AI3V
    AI3V Ham Member QRZ Page
    Call them and ask...
    Rege
  7. K8AI
    Is that how you found out?
    The MSDS doesn't list too many details.
  8. AI3V
    To be honest I think I read it somewhere, other sources claim oleic acid, and a carrier that polymerizes (sp?) Into a sticky goo.
    My experence with the stuff is its good to find if a sliding contact is bad, and then get that part on order to replace. I have had poor long term results using it.
    YMMV :)
    Rege
    K8PG likes this.
  9. KM1H
    KM1H Ham Member QRZ Page
    Spraying on a roller inductor is just asking for trouble; all that dissolved conductive mess is all over it. The spray is 5% product and 95% propellant that never completely evaporates.
    Disc Brake spray cleaner works to get rid of the crud but dont use on anything that will be chemically attacked, dissolved, softened, etc.
    Carl
  10. WA6SW
    WA6SW Ham Member QRZ Page
    Who said spray on?
