ad: KF7PMW-1
For Sale Cleaning out stuff, updated 11/9
Discussion in 'Ham Radio Gear For Sale' started by WB4IUY, Nov 9, 2018.
  1. WB4IUY
    WB4IUY XML Subscriber QRZ Page
    Radios & acc, PS's, Antennas, Repeater misc, Test Gear, Crystals, & Parts - Updated 11/09/18. I've tried to organize it a bit to make it easier to look through. All items located and shipped from Youngsville NC, USA. wb4iuy@eastrc.org
    ***********ANTENNA, CABLES, & ACCESSORIES***********
    - 7 element 220mhz Yagi, shortened version of the Cushcraft A220-11. Shipped with new hardware. $75, shipped free in the USA.
    - Johnson Viking Matchbox 275 watts, CLEAN! Good condition, original paint. Modified many years ago to include a coaxial output terminal on back SO-239. No longer needed in my shack, all antennas now band specific. Built like a tank, one of the most famous transmatches ever! $150 + shipping
    - Larson UHF mobile antenna for NMO base. $15 with free ship in the USA
    - VHF Mobile Antennas (2m):
    2ea. MaxRad MFT120 Field Tunable 118-940 MHz 1/4wl antenna with NMO connector kit - $15 ea. shipped in the USA
    - I have several lengths of coax for sale, some with terminations. This is almost all used, pulled from two locations where I had gear, and some from around the shack over the years. It is all good. Here's a list of what I have on my server at:
    http://207.126.49.184/wb4iuy/feedline1.txt
    Price does not include shipping.
    - I have a load of coax jumpers for sale, with various terminations. This is almost all used, pulled from two locations where I had gear, and some from around the shack over the years. It is all good. Here's a list of what I have on my server at:
    http://207.126.49.184/wb4iuy/jumpers.txt
    ***********PACKET STUFF***********
    - TNC Cable, RJ-45 Icom Mic to Kantronics KPC-3. $15 shipped free in the USA.
    - TNC Cable, 8-Pin round Icom Mic connector to Kantronis KPC-3. $15 shipped free in the USA.
    ***********POWER SUPPLIES & WALL WARTS***********
    - I have several 12vdc power supplies that will handle 20 amps continuous. These have binding post connectors that will also accept banana plugs, and a power "on" indicator. These power supplies have a whisper-quiet fan for cooling, and a main power switch for control. $45 each shipped in the USA.
    - Tripp Lite BC425FC Power Inverter. It has been modified to accept an external connection to auto batteries, etc. This is a heavy-duty 425 watt continuous inverter, and much more versatile with an external 12vdc power source. $30 shipped.
    - Panasonic KX-A09 AC DC Adapter, 120vac in, 12 VDC 200ma out, 5.5mm OD 2.1 mm ID connector. Modified so center of plug is +DC. $9 + Free ship in USA.
    - FAIRWAY WN10E-051 AC/DC POWER ADAPTER OUTPUT 5VDC 2A. 5.5mm x 2.1mm coaxial plug. $9 + Free ship in the USA
    - Sharp AC Adaptor model EA-63A, 120vac input, 6vdc 300ma output, w/connector. $10 w/Free Ship in the USA
    - DVE DV-9034A AC Adaptor, 120vac in, 9 VAC 3.4A out, 5.5mm OD 2.0 mm ID. $12 w/free ship in the USA
    - UBEE DSA-18W-12 DC Adaptor, 100-240vac in, 12VDC 1.5A out, 5.5mm OD 2.0 mm ID. $12 w/free ship in the USA
    - EXP9704 DC Adaptor, 120vac in, 10VDC 500mA out, 5.5mm OD 2.0 mm ID. $12 w/free ship in the USA
    - WJ-Y666-12 DC Adaptor + Charging Base w/LED, 120vac in, 12VDC 500mA out. $13 w/free ship in the USA
    - Basler Electric Transformer, 120vac in, 12VAC 25VA out, screw terms, fused. $13 w/free ship in the USA
    - Health-O-Meter Pelouze DC Adaptor, 120vac in, 9VDC 100mA out, 1/8" plug. $12 w/Free Ship in the USA
    - RH41-0750800DU AC DC Adaptor, 120vac in, 7.5 VDC 800mA out, 3.8mm OD 1.3 mm ID. $9 w/Free Ship in the USA
    - Garmin Power Supply 362-00042-00. $9 + $4.50 shipping in the USA
    - HA35U-0603 AC DC Adapter, 120vac in, 6 VDC 300mA out, 5.5mm OD 2.1 mm ID. $9 w/free ship in the USA
    - Xtend AC Power Adaptor AD-740-1200 100-240 vac input, 20 vdc 2 a output, 4 pin . $13 w/free ship in the USA
    - APD Asian Power Devices DA-60F19, 19 VDC 3.16A out, 6.5mm OD 3.0 mm ID. $15 w/free ship in the USA
    - 280903RO3CT AC DC Adapter, 120vac in, 9 VAC 300ma out, 5.5mm OD 2.1 mm ID. $9 w/free ship in USA
    - Cambridge SoundWorks AC Adapter TEAD-48-091000U. $9 w/free ship in the USA
    - TELEPHONE AC Adapter HADW-1 Power Supply 12vdc 900mA MD242-120080 Unbranded/Gene. $9 w/free ship in the USA
    - Ault power supply, 8541, 24 v output. $9 w/free ship in the USA
    - Sharp AC Adaptor model EA-17E, 120vac input, 3vdc 150ma output, no plug. $8 w/free ship in the USA
    - Verifone 01536-01 AC Adapter, 120vac in, 8.3 VAC 1A out, 5.5mm OD 2.5 mm ID. $8 w/free ship in the USA
    - Craig AC Adapter Model 9235, 120vac input, 3vdc 150ma output, no plug. $8 w/Free Ship in the USA
    - Black & Decker AC Adaptor 5102404-05, CD08A, 14.6vac 130ma output, no connector. $8 w/free ship in the USA
    - Direct Plug-In Battery Charger Model 680986-44, 120vac input, 6.5vac 250ma out.. $8 w/Free Ship in the USA
    ***********MANUALS, BOOKS & HAM RADIO MAGAZINES***********
    - I have loads of books & magazines. Here's a list of what I have on my server at: http://207.126.49.184/wb4iuy/sale-books.txt
    ***********REPEATER STUFF***********
    - RCA Series 1000 VHF repeater on 147.315/147.915. This was in my site in Wilson for a number of years and works great. I've upgraded the power supply and PA. No controller. This beast is sitting in my workshop and must go. You can see more about it online at
    http://www.ipass.net/teara/14730.html $200.
    ***********Yaesu 101ZD Parts - NOTE, message me to negotiate pricing on these bits***********
    - YAESU FT-101 ZD PB-2192B Trimmer Board
    - YAESU FT-101ZD Noise Blanker & Delay dual potentiometer
    - CARD EDGE CONNECTORS CIRCUIT BOARD SOCKET Card Plugs for YAESU FT-101 ZD
    - Rear Panel with all connectors for YAESU FT-101ZD Radio
    - YAESU FT-101 ZD Chassis Mount Neutralization Capacitor and bracket
    - YAESU FT-101ZD Compressor Level potentiometer
    - YAESU FT-101 ZD Preselector Unit Complete
    ***********Yaesu 101B, E, EE, EX, F Parts - NOTE, message me to negotiate pricing on these bits***********
    - YAESU FT-101 B E EE EX F VC2 Antenna Loading Capacitor
    - YAESU FT-101 B Front Sub-panel lights Chassis
    - YAESU FT-101 B E EE EX F T-12 Low Frequency Choke 20mH @ .5A
    - YAESU FT-101 B E EE EX F 10pf Ajustable Chassis Mount Neutralization Capacitor
    - YAESU FT-101 PB-1714 Driver Tube Board with Tube Socket
    - YAESU FT-101 B E EE EX F Final Amplifier Plate Choke L7 Plate Coupling caps clip
    - Rear Panel with all connectors for YAESU FT-101B Radio
    - YAESU FT-101 B E EE EX F FRONT PANEL Faceplate Trim Ring Ham Radio
    - YAESU FT-101 B FRONT PANEL PLATE HAM RADIO Faceplate
    - Yaesu FT-101B Ceramic Driver Tube Socket
    - Yaesu FT-101B Chassis Mount Relay Socket
    - YAESU FT-101 B E EE EX F PB-1180 High Frequency I.F. Board Assembly
    - YAESU FT-101 B E EE EX F Preselector Unit Complete
    - Clarifier Control for YAESU FT-101B Radios
    - YAESU FT-101 B E EE EX F PB-1344A Internal Fixed Freq Oscillator Board & Switch
    ***********Heathkit Parts - NOTE, message me to negotiate pricing on these bits***********
    - Heathkit SB-100 SB-101 SB102 Relay Socket
    - Heathkit SB-620 Scanalyzer PIP Gain Pot Assembly
    - Heathkit SB-620 Scanalyzer Variable Sweep Width Pot Assembly
    - Heathkit SB-620 Scanalyzer Amplitude Scale Switch Assembly
    - Heathkit SB-100 SB-101 SB102 RF Tank Circuit Cage, NO LID
    - Heathkit SB-620 Scanalyzer Gang of 4 Rear Apron Pots Astig Log Vert Horiz Pos
    - Heathkit SB-620 Scanalyzer Group of 6 Tube Sockets
    - Heathkit SB-620 Scanalyzer Variable Sweep Rate Pot Assembly
    - Heathkit SB-620 Scanalyzer Sweep Width Switch Assembly
    ***********COMMERCIAL RADIO BITS AND PROJECT STUFF***********
    - SwinTek Full Duplex Radio Interface System MK200DV & MK200DT with Charger & Battery. 75.44 mhz and 171.045 mhz, great for use around house for full duplex audio to and fron shack. $50 w/Free Shipping in the USA
    - RFM DNT900 900 Mhz Point to point communications link and developers package NEW. Great 900mhz building blocks. $80 w/Free Ship in the USA
    - Motorola S7624A Cell Phone Booster 3 Watts StarTac SLN3506A SLN3500B SLN3501B 800mhz amp. These have been put up on 900mhz, good project piece. $18 + free ship in the USA
    - RCA Series 1000 test panel. Perfect for any of the factory alignment tests outlined in the service manuals for the mobiles, base stations, and repeaters. I used it with a previous Series 1000 repeater I had in ham operation. $25 + shipping.
    - Several models of Tone Reeds for Motorola radios. $5 each + shipping. I have a list on my server that I update each time a reed sells, you can see it at
    http://207.126.49.184/wb4iuy/reeds.txt
    - I have several Motorola & GE Channel Elements used in the conversion of the older crystal rigs to the ham bands. There are too many to list here, but I have an up-to-date listing of them on my server at:
    http://207.126.49.184/wb4iuy/elements.txt These are $5 each + shipping.
    - Motorola HT-440 464.200 469.200 2CH #1, untested, for parts $6.50 + shipping
    - Motorola HT-440 464.200 469.200 2CH #2, untested, for parts $10.00 + shipping
    - Motorola HT-440 464.200 469.200 2CH #3, untested, for parts $10.00 + shipping
    - Motorola HT-440 464.200 469.200 2CH #4, untested, for parts $12.00 + shipping
    - Motorola HT-440 464.200 469.200 2CH #5, untested, for parts $12.00 + shipping
    - Motorola HT-440 464.200 469.200 2CH #6, untested, for parts $12.00 + shipping
    - Motorola Mostar UHF W/MIC 464.200 2CH 30W #1, Tested 33 watts output, 500uv rx sensitivity, 2 channels 464.200, 469.200. Speaker audio out on pins 8 & 15 on rear DB-15 connector. v
    - Motorola Mostar UHF W/MIC 464.200 2CH 30W #2, Tested 30 watts output, .5uv rx sensitivity, 2 channels 464.200, 469.200. Speaker audio out on pins 8 & 15 on rear DB-15 connector. $20 + shipping
    - Motorola Mostar UHF W/MIC 464.200 2CH 30W #3, Tested 0 watts output (bad TX, driver is running, could see it on scope) .3uv rx sensitivity, 2 channels 464.200, 469.200. Speaker audio out on pins 8 & 15 on rear DB-15 connector. $20 + shipping
    - Motorola Mostar UHF W/MIC 464.200 2CH 30W #4. Tested 30 watts output, .7uv rx sensitivity, 2 channels 464.200, 469.200. Speaker audio out on pins 8 & 15 on rear DB-15 connector. $20 + shipping
    - Motorola NLN7654A Charger for HT440, HT90 #6 BAD, Works with NLN7401 Batteries and others. Overnight drop in charger. Tested bad, very clean, no idea what the problem is. $12 + shipping
    ***********TEST EQUIPMENT***********
    - Microlab AB-15N Type N Coaxial 50 Ohm 15db attenuator, silver plated. $12 w/free ship in the USA
    - Measurements 80-ZH1 Pad 2:1 Voltage Ratio Microwave RF 6dB Type-N(m) UHF(f) . $20 + $3.50 shipping in the USA
    - DAVEN 155-50-6 ATTENUATOR FIXED RESISTIVE TYPE 5905-230-5162 50/50 6DB "PI". $12 w/Free Ship in the USA
    - Vintage 1946 General Radio Vacuum Tube Voltmeter, Type 1800. This is the most perfect specimen of the General Radio 1800-A I have ever seen. From the wooden cabinet, to the beautiful face, to the full accessory compartment, this thing is museum quality. It works!! I would recommend that it be recapped, but it was stored and kept in immaculate condition for over 70 years!!!! $300 + shipping.
    - 2 units of RLC Electronics M-3106 30db dual directional couplers with type N male and female connections. Orignally used 800-900 mhz. Tested at 70cm & found to work resonably well, used on 33 & 23 cm bands by others. $50 each + shipping in the USA.
    - Collins 70A1-MW balanced probe. Missing one probe tip, otherwise intact and functional. $35 shipped in the USA.
    - HP-J281A Coaxial Waveguide adapter, WR137 to N Female. Good condition, 5.3-8.3 ghz. $25 + shipping
    - HP-431B Power Meter. Uses Thermistor mounts. Bought it as a spare for parts for my unit, but don't need it. These things seem to be bullet proof. This one is the unit only (no cables or mount). Nothing pretty but it works. 10 uwatts to 10 mw. $40 + shipping.
    - Lenkurt Test Transformers, #583C & #583D. $25 + shipping.
    - CALRAD SR-16 STANDING WAVE BRIDGE METER $16 shipped in the USA
    - Vintage James Millen Absorbtion Frequency Meter, 3.4 - 8.2 mhz $17.50 + shipping
    - Vintage James Millen Absorbtion Frequency Meter, 7.8 - 19.0 mhz $17.50 + shipping
    ***********PARTS & COMPONENTS***********
    - Low Pass Filters, $8 ea. shipped.
    3ea. Auto-Mate 20-1-LPF, cut off freq 400 mhz, type N connectors
    5ea. Bird C-2016-1E low pass filter, cut off freq 420 mhz, type N connectors
    2ea. Bird 241-0057-009 low pass filter, cut off freq 420 mhz, BNC connectors
    - Type N connectors for RG-8/RG-214/9913/Flexi-4 sytle feedline. All cuts from cable but clean, $1.00 ea. Lots of them!
    - Unimax SL-Series Key Lock switches, new in bag. Perfect for installing key locks on radio equipment, in amplifiers, on HV power supplies, etc. Complete with 2 barrel keys, 4a @ 250 vac switch, chassis bezel, and all all mounting hardware. $5 ea. + shipping in the USA.
    - Assortment of 9ea. chassis mount key lock switches w/keys, all new. $20 for the batch, shipped in the USA.
    - Weller Soldering Station parts:
    1ea. D83 tip for Weller MP126 & MP131 - $2.50 ea. shipped in the USA
    3ea A85 tips for Weller EC1000 & EC2000 - $2.50 ea. shipped in the USA
    1ea. A89 tip for Weller WEC24 & EC1201 - $2.50 shipped in the USA
    - Teltone M-8870 DTMF decoder chip with all application info, new in bag. Bought several for a repeater controller project, 1 left. $7.50 + shipping in the USA.
    - Loads of panel meters for sale. Too many to list, I've put a list of them online at
    http://207.126.49.184/wb4iuy/meters.txt
    I update it each time a meter is sold. $10 each. If you want multiples, contact me and let's work a deal.
    - TDA-7000 FM Receiver IC with application notes from Radio Shack (Archer), #276-1304. Considered as collectable electronics, the few that are remaining are selling online for $20. This is still sealed in the original package. I used these to build 6m FM receivers several years ago. This is the last one left. $10 + shipping.
    - ISD1000A Voice Record/Playback chip w/20 second memory with application notes from Radio Shack (Archer), #276-1325. VERY easy to build digital voice storage with, I used these in some of my homebrew repeater controllers for voice ID functions. This is still sealed in the original package. I have 1 of these left. $15 + shipping.
    - Signetics SC87C51CCN40 8-bit dip40 microprocessor, new. I used some of these for homebrew freq counter projects and have this one left, never used. $5 + shipping.
    ***********CRYSTALS***********
    - Batch of James Knight Type T-9 Quartz xtal units, Metal can like tube w/Octal base. 50kc, 97kc, 99kc, 101kc, 103kc, 105kc, 107kc, 130kc, 144kc, & 150kc (2pcs). $5ea or $50 for the lot + shipping.
    - Lots of crystal ovens with 8 pin octal bases. $5 each.
    - 10.795 mhz crystals: These are custom manufactured 10.795 mhz crystals used to modify the old 23 channel CB radios to fill in the 20khz gaps in the channel selector found between channels 3&4, 7&8, 11&12, 15&16, and the gap that was once called "22A" at 278.235. I had a batch of these made back in 1994 when I was converting a bunch of CB radios for 10 meter AM amateur use, and still have a few left. They were made by Jan Crystals, and are high accuracy solder-in crystals. I have 5 of these. These are $15 each + shipping or $50 for the batch with free shipping.
    - QUARTZ CRYSTAL RESONATOR MARCONI FREQUENCY 8960 KC NEW SURPLUS $10 shipped
    - Vintage Radiomarine Corp. Quartz Crystal 2215 KHz Model R1 $13 shipped
    - James Knight Quartz Crystal , 17400 kc, type H73 holder $13 shipped
    - QUARTZ CRYSTAL RESONATOR MARCONI FREQUENCY 8960 KC NEW SURPLUS. $10, free ship in USA
    ***********TUBES & Sockets***********
    - RCA 866A Rectifier tubes: I have a batch of these RCA 866A mercury vapor rectifier tubes. I've tested all of them in a 2-stage process... 1st test on my Hickok KS-5727-L1 to check for shorts. 2nd test, 30 minute filament bake in on my Heathkit Warrior amp, then a full load test on the Warrior. These all are good, and most don't show much usage. The "A" version is the later model with much higher voltage rating and the cathode shield. $25 each, shipped.
    - 3CX100A5 (7289) Planar Triode: Used 3CX100A5 (7289) Planar Triode Electron Tube pulled from working AM-3204A / TRC-24 Amp $18 shipped
    - GL-5544 Thyratron Tube: These are good pulls from a friend who services x-ray machines as part of required maintenance. I bought them with intentions of building a thyratron welder, but I'll never get around to it. I have several. $35 shipped
    - 6807 Thyratron Tube: These are good pulls from a friend who services x-ray machines as part of required maintenance. I bought them with intentions of building a thyratron welder, but I'll never get around to it. I have 2 or these. $35 shipped
    - Amphenol Chicago 49 4 Pin Ceramic Tube Sockets for 866 816, & 3B28. These are good used sockets for 866 and variants, 816, and 3B28 rectifiers. Chassis flange mount, or convertable to through chassis mount by removing clip ring and flange. Amphenol Chicago 49. Lots on hand. $5 each
    - EF Johnson Ceramic Tube Socket 122-244-1 for EL6B, 576A, 5544, 6807, and others. Clean, used pulls in great condition. $20 each shipped.
    - 40 pcs of National Grid Grip Grid / Plate connections with HV lead for .600" diameter Vacuum Tube playe or grid terminals. $40 for the lot, shipped.
    ***********COMPUTER STUFF***********
    - I have lots of parts for the shack computer. Here's a list of what I have on my server at:
    http://207.126.49.184/wb4iuy/sale-computer.txt
  2. WB4IUY
    More pics...
  3. WB4IUY
    More pics...
  4. WB4IUY
    More pics...
  5. WB4IUY
    Last pic...
    KI7KCW and KH6KG like this.
  6. K9ZF
    K9ZF Ham Member QRZ Page
    I will take both of the packet cables:
    Is paypal OK?
    Dan K9ZF
    WB4IUY likes this.
  7. K9ZF
    The best way to reach me is email:
    k9zf@yahoo.com
    WB4IUY likes this.
  8. WB4IUY
    Email sent, Dan. Tnx!
  9. WB4IUY
    Sold:
    - TNC Cable, 8-Pin round Icom Mic connector to Kantronics KPC-3.
  10. KS4PC
    KS4PC Ham Member QRZ Page
    Hello from Darryl I am looking for plate transformer to power 4X 811s also any thing I can use for amps with 813s thanks Darryl KS4PC 352 283 3977 text is fast way to contact
  11. QRZ
    Important Rules
    Have you read our Swapmeet Rules?
    This forum enforces a set of buying/selling rules for the benefit of all users. Make sure that you're familiar with the rules before posting or replying in this area. Our moderators review every post in this forum and will flag or delete those that do not conform.
