For Sale Cleaning out a load of stuff...
Discussion in 'Ham Radio Gear For Sale' started by WB4IUY, Sep 8, 2018.
  1. WB4IUY
    WB4IUY XML Subscriber QRZ Page
    Radios & acc, PS's, Antennas, Repeater misc, Test Gear, Crystals, & Parts - Updated 9/7/18. I've tried to organize it a bit to make it easier to look through. All items located and shipped from Youngsville NC, USA. Email me at wb4iuy@eastrc.org with any questions or offers.
    ***********ANTENNA, CABLES, & ACCESSORIES***********
    - Johnson Viking Matchbox 275 watts, CLEAN! Good condition, original paint. Modified many years ago to include a coaxial output terminal on back SO-239. No longer needed in my shack, all antennas now band specific. Built like a tank, one of the most famous transmatches ever! $170 + shipping
    - HF Yagi: Cushcraft A3S, recently totally overauled. I've had it for several years and had great luck with it. I have completely disassembled this antenna (including the traps), cleaned all of trap electrical connections and installed new stainless screws everywhere, swapt all of the traps and tagged them with the correct designation (those fade/fall off over the years), fabricated a more robust PVC/epoxy center support for the driven element (like I have on others), marked and tagged eveything for easy reassembly. $375 and I pay the shipping on this large/heavy container in the USA.
    - VHF Mobile Antennas (2m/6m):
    2ea. MaxRad MFT120 Field Tunable 118-940 MHz 1/4wl antenna with NMO connector kit - $15 ea. shipped in the USA
    1ea. Larson Kulrod 144-174 mhz 5/8wl base loaded for NLA mount - $15 shipped in the USA
    - Andrew LDF4-50A Heliax jumpers, 3' long, Andrews L44AW type N MALE connectors. $10 ea + shipping, normally $70 each! The connectors are worth more than this.
    - I have several lengths of coax for sale, some with terminations. This is almost all used, pulled from two locations where I had gear, and some from around the shack over the years. It is all good. Here's a list of what I have on my server at: http://www.ipass.net/wb4iuy/feedline1.txt . Price does not include shipping.
    - I have a load of coax jumpers for sale, with various terminations. This is almost all used, pulled from two locations where I had gear, and some from around the shack over the years. It is all good. Here's a list of what I have on my server at: http://www.ipass.net/wb4iuy/jumpers.txt . Price does not include shipping.
    ***********PACKET STUFF***********
    - Packet TNC to radio interface cable, Icom 8-pin round mic connector to KPC-3. $12.50 shipped in the US.
    - Kantronics KamPlus Version 6.1. Recently replaced the electrolytics and did all hardware updates/mods. $150 shipped in the USA.
    ***********POWER SUPPLIES***********
    - I have several 12vdc power supplies that will handle 20 amps continuous. These have binding post connectors that will also accept banana plugs, and a power "on" indicator. These power supplies have a whisper-quiet fan for cooling, and a main power switch for control. $45 each shipped in the USA.
    - Tripp Lite BC425FC Power Inverter. It has been modified to accept an external connection to auto batteries, etc. This is a heavy-duty 425 watt continuous inverter, and much more versatile with an external 12vdc power source. $30 shipped.
    ***********REPEATER STUFF***********
    - RCA Series 1000 VHF repeater on 147.315/147.915. This was in my site in Wilson for a number of years and works great. I've upgraded the power supply and PA. No controller. This beast is sitting in my workshop and must go. You can see more about it online at http://www.ipass.net/teara/14730.html . $300.
    ***********Yaesu 101ZD Parts - NOTE, message me to negotiate pricing on these bits***********
    - YAESU FT-101 ZD PB-2192B Trimmer Board
    - YAESU FT-101ZD Noise Blanker & Delay dual potentiometer
    - CARD EDGE CONNECTORS CIRCUIT BOARD SOCKET Card Plugs for YAESU FT-101 ZD
    - Rear Panel with all connectors for YAESU FT-101ZD Radio
    - YAESU FT-101 B Front Sub-panel lights Chassis
    - YAESU FT-101 ZD Chassis Mount Neutralization Capacitor and bracket
    - YAESU FT-101 B E EE EX F VC2 Antenna Loading Capacitor
    - YAESU FT-101ZD Compressor Level potentiometer
    - YAESU FT-101 ZD Preselector Unit Complete
    ***********Yaesu 101B, E, EE, EX, F Parts - NOTE, message me to negotiate pricing on these bits***********
    - YAESU FT-101 B E EE EX F Set of 4 Front Panel Slider Switches
    - YAESU FT-101 B E EE EX F T-12 Low Frequency Choke 20mH @ .5A
    - YAESU FT-101 B E EE EX F 10pf Ajustable Chassis Mount Neutralization Capacitor
    - YAESU FT-101 PB-1714 Driver Tube Board with Tube Socket
    - YAESU FT-101 B E EE EX F Final Amplifier Plate Choke L7 Plate Coupling caps clip
    - Rear Panel with all connectors for YAESU FT-101B Radio
    - YAESU FT-101 B E EE EX F FRONT PANEL Faceplate Trim Ring Ham Radio
    - YAESU FT-101 B FRONT PANEL PLATE HAM RADIO Faceplate
    - Yaesu FT-101B Ceramic Driver Tube Socket
    - Yaesu FT-101B Chassis Mount Relay Socket
    - YAESU FT-101 B E EE EX F PB-1180 High Frequency I.F. Board Assembly
    - YAESU FT-101 B E EE EX F Preselector Unit Complete
    - Clarifier Control for YAESU FT-101B Radios
    - YAESU FT-101 B E EE EX F PB-1344A Internal Fixed Freq Oscillator Board & Switch
    ***********Heathkit Parts - NOTE, message me to negotiate pricing on these bits***********
    - Heathkit SB-100 SB-101 SB102 Relay Socket
    - Heathkit SB-620 Scanalyzer PIP Gain Pot Assembly
    - Heathkit SB-620 Scanalyzer Variable Sweep Width Pot Assembly
    - Heathkit SB-620 Scanalyzer Amplitude Scale Switch Assembly
    - Heathkit SB-100 SB-101 SB102 RF Tank Circuit Cage, NO LID
    - Heathkit SB-620 Scanalyzer Gang of 4 Rear Apron Pots Astig Log Vert Horiz Pos
    - Heathkit SB-620 Scanalyzer Group of 6 Tube Sockets
    - Heathkit SB-620 Scanalyzer Variable Sweep Rate Pot Assembly
    - Heathkit SB-620 Scanalyzer Sweep Width Switch Assembly
    ***********COMMERCIAL RADIO BITS***********
    - RCA Series 1000 test panel. Perfect for any of the factory alignment tests outlined in the service manuals for the mobiles, base stations, and repeaters. I used it with a previous Series 1000 repeater I had in ham operation. $25 + shipping.
    - Several models of Tone Reeds for Motorola radios. $5 each + shipping. I have a list on my server that I update each time a reed sells, you can see it at http://www.ipass.net/wb4iuy/reeds.txt .
    - I have several Motorola & GE Channel Elements used in the conversion of the older crystal rigs to the ham bands. There are too many to list here, but I have an up-to-date listing of them on my server at: http://www.ipass.net/wb4iuy/elements.txt . These are $5 each + shipping.
    - Motorola HT-440 464.200 469.200 2CH #1, untested, for parts $6.50 + shipping
    - Motorola HT-440 464.200 469.200 2CH #2, untested, for parts $10.00 + shipping
    - Motorola HT-440 464.200 469.200 2CH #3, untested, for parts $10.00 + shipping
    - Motorola HT-440 464.200 469.200 2CH #4, untested, for parts $12.00 + shipping
    - Motorola HT-440 464.200 469.200 2CH #5, untested, for parts $12.00 + shipping
    - Motorola HT-440 464.200 469.200 2CH #6, untested, for parts $12.00 + shipping
    - Motorola Mostar UHF W/MIC 464.200 2CH 30W #1, Tested 33 watts output, 500uv rx sensitivity, 2 channels 464.200, 469.200. Speaker audio out on pins 8 & 15 on rear DB-15 connector. v
    - Motorola Mostar UHF W/MIC 464.200 2CH 30W #2, Tested 30 watts output, .5uv rx sensitivity, 2 channels 464.200, 469.200. Speaker audio out on pins 8 & 15 on rear DB-15 connector. $20 + shipping
    - Motorola Mostar UHF W/MIC 464.200 2CH 30W #3, Tested 0 watts output (bad TX, driver is running, could see it on scope) .3uv rx sensitivity, 2 channels 464.200, 469.200. Speaker audio out on pins 8 & 15 on rear DB-15 connector. $20 + shipping
    - Motorola Mostar UHF W/MIC 464.200 2CH 30W #4. Tested 30 watts output, .7uv rx sensitivity, 2 channels 464.200, 469.200. Speaker audio out on pins 8 & 15 on rear DB-15 connector. $20 + shipping
    - Motorola Mostar UHF W/MIC 464.200 2CH 30W #5. Tested 30 watts output, 200uv rx sensitivity, 2 channels 464.200, 469.200. Speaker audio out on pins 8 & 15 on rear DB-15 connector. $20 + shipping
    - Motorola NLN7654A Charger for HT440, HT90 #6 BAD, Works with NLN7401 Batteries and others. Overnight drop in charger. Tested bad, very clean, no idea what the problem is. $12 + shipping
    ***********TEST EQUIPMENT***********
    - 2 units of RLC Electronics M-3106 30db dual directional couplers with type N male and female connections. Orignally used 800-900 mhz. Tested at 70cm & found to work resonably well, used on 33 & 23 cm bands by others. $50 each + shipping in the USA.
    - Collins 70A1-MW balanced probe. Missing one probe tip, otherwise intact and functional. $35 shipped in the USA.
    - HP-J281A Coaxial Waveguide adapter, WR137 to N Female. Good condition, 5.3-8.3 ghz. $25 + shipping
    - HP-431B Power Meter. Uses Thermistor mounts. Bought it as a spare for parts for my unit, but don't need it. These things seem to be bullet proof. This one is the unit only (no cables or mount). Nothing pretty but it works. 10 uwatts to 10 mw. $40 + shipping.
    - Lenkurt Test Transformers, #583C & #583D. $25 + shipping.
    - CALRAD SR-16 STANDING WAVE BRIDGE METER $16 shipped in the USA
    - Vintage James Millen Absorbtion Frequency Meter, 3.4 - 8.2 mhz $17.50 + shipping
    - Vintage James Millen Absorbtion Frequency Meter, 7.8 - 19.0 mhz + shipping
    ***********PARTS & COMPONENTS***********
    - Connectors, NEW IN BAG. These are all $1.75 each, shipped. Here's what I have:
    8ea. BNC Crimp, RG-59 size, KS-19224
    2ea. TNC Crimp male, RG-58 size, RFT-1202-2
    2ea. TNC Clamp, RG-59 size, RFT-1801
    3ea. BNC Clamp, RG-58 size
    3ea. BNC Crimp, RG-59 size
    29ea. BNC Crimp, 735 cable (header, mini-58 size), KS23558
    23ea. BNC 90 degree right angle crimp, RG-59 size, Specialty Connectors #28P263-1
    4ea. BNC Clamp, Radiall 142017, RG-59 size
    5ea. BNC 90 degree right angle crimp, R734A cable size (mini-58)
    2ea. KS-14317-13 Crimp
    4ea. Mini-UHF Female Crimp, RFU-601-1
    - Low Pass Filters, $8 ea. shipped.
    3ea. Auto-Mate 20-1-LPF, cut off freq 400 mhz, type N connectors
    5ea. Bird C-2016-1E low pass filter, cut off freq 420 mhz, type N connectors
    2ea. Bird 241-0057-009 low pass filter, cut off freq 420 mhz, BNC connectors
    - Type N connectors for RG-8/RG-214/9913/Flexi-4 sytle feedline. All cuts from cable but clean, $1.00 ea. Lots of them!
    - Unimax SL-Series Key Lock switches, new in bag. Perfect for installing key locks on radio equipment, in amplifiers, on HV power supplies, etc. Complete with 2 barrel keys, 4a @ 250 vac switch, chassis bezel, and all all mounting hardware. $5 ea. + shipping in the USA.
    - Assortment of 9ea. chassis mount key lock switches w/keys, all new. $20 for the batch, shipped in the USA.
    - Weller Soldering Station parts:
    1ea. D83 tip for Weller MP126 & MP131 - $2.50 ea. shipped in the USA
    3ea A85 tips for Weller EC1000 & EC2000 - $2.50 ea. shipped in the USA
    1ea. A89 tip for Weller WEC24 & EC1201 - $2.50 shipped in the USA
    - Teltone M-8870 DTMF decoder chip with all application info, new in bag. Bought several for a repeater controller project, 1 left. $7.50 + shipping in the USA.
    - Loads of panel meters for sale. Too many to list, I've put a list of them online at http://www.ipass.net/wb4iuy/meters.txt and update it each time a meter is sold. $10 each. If you want multiples, contact me and let's work a deal.
    - TDA-7000 FM Receiver IC with application notes from Radio Shack (Archer), #276-1304. Considered as collectable electronics, the few that are remaining are selling online for $20. This is still sealed in the original package. I used these to build 6m FM receivers several years ago. This is the last one left. $10 + shipping.
    - ISD1000A Voice Record/Playback chip w/20 second memory with application notes from Radio Shack (Archer), #276-1325. VERY easy to build digital voice storage with, I used these in some of my homebrew repeater controllers for voice ID functions. This is still sealed in the original package. I have 1 of these left. $15 + shipping.
    - Signetics SC87C51CCN40 8-bit dip40 microprocessor, new. I used some of these for homebrew freq counter projects and have this one left, never used. $5 + shipping.
    ***********CRYSTALS***********
    - Batch of James Knight Type T-9 Quartz xtal units, Metal can like tube w/Octal base. 50kc, 97kc, 99kc, 101kc, 103kc, 105kc, 107kc, 130kc, 144kc, & 150kc (2pcs). $5ea or $50 for the lot + shipping.
    - Lots of crystal ovens with 8 pin octal bases. $5 each.
    - 10.795 mhz crystals: These are custom manufactured 10.795 mhz crystals used to modify the old 23 channel CB radios to fill in the 20khz gaps in the channel selector found between channels 3&4, 7&8, 11&12, 15&16, and the gap that was once called "22A" at 278.235. I had a batch of these made back in 1994 when I was converting a bunch of CB radios for 10 meter AM amateur use, and still have a few left. They were made by Jan Crystals, and are high accuracy solder-in crystals. I have 5 of these. These are $15 each + shipping or $50 for the batch with free shipping.
    - QUARTZ CRYSTAL RESONATOR MARCONI FREQUENCY 8960 KC NEW SURPLUS $10 shipped
    - Vintage Radiomarine Corp. Quartz Crystal 2215 KHz Model R1 $13 shipped
    - James Knight Quartz Crystal , 17400 kc, type H73 holder $13 shipped
    ***********TUBES & Sockets***********
    - RCA 866A Rectifier tubes: I have a batch of these RCA 866A mercury vapor rectifier tubes. I've tested all of them in a 2-stage process... 1st test on my Hickok KS-5727-L1 to check for shorts. 2nd test, 30 minute filament bake in on my Heathkit Warrior amp, then a full load test on the Warrior. These all are good, and most don't show much usage. The "A" version is the later model with much higher voltage rating and the cathode shield. $25 each, shipped.
    - 3CX100A5 (7289) Planar Triode: Used 3CX100A5 (7289) Planar Triode Electron Tube pulled from working AM-3204A / TRC-24 Amp $18 shipped
    - GL-5544 Thyratron Tube: These are good pulls from a friend who services x-ray machines as part of required maintenance. I bought them with intentions of building a thyratron welder, but I'll never get around to it. I have several. $35 shipped
    - 6807 Thyratron Tube: These are good pulls from a friend who services x-ray machines as part of required maintenance. I bought them with intentions of building a thyratron welder, but I'll never get around to it. I have 2 or these. $35 shipped
    - Amphenol Chicago 49 4 Pin Ceramic Tube Sockets for 866 816, & 3B28. These are good used sockets for 866 and variants, 816, and 3B28 rectifiers. Chassis flange mount, or convertable to through chassis mount by removing clip ring and flange. Amphenol Chicago 49. Lots on hand. $5 each
    - EF Johnson Ceramic Tube Socket 122-244-1 for EL6B, 576A, 5544, 6807, and others. Clean, used pulls in great condition. $20 each shipped.
    - 40 pcs of National Grid Grip Grid / Plate connections with HV lead for .600" diameter Vacuum Tube playe or grid terminals. $40 for the lot, shipped.
    ***********Computer Stuff***********
    - Batch of internal removable media drives: 4ea 3.5" floppy drives, 5ea CD players, and 1 DVD player. All good and clean. $5 each + shipping of $50 for the lot shipped free in the US.
  2. WB4IUY
    More pics...
  3. WB4IUY
    More pics...
  4. WB4IUY
    Last of pics. Message me if there's anything here you need to see a better photo of.
  5. KI7AAR
    KI7AAR Premium Subscriber QRZ Page
    I’m interested in the low pass filters but, the photos aren’t clear enough to read the specs.
  6. TI2CDA
    TI2CDA Ham Member QRZ Page
    Email sent
  7. WB4IUY
    That's not specs printed on the filters, it's part #'s, low freq cutoff of 400 & 420 mhz, and such. You'll have to google the part #'s of Auto-Mate 20-1-LPF, Bird C-2016-1E, and Bird 241-0057-009 to get more info.
  8. WB4IUY
    The Packet Radio cable, all of the LDF4-50A Heliax jumpers, and the Larson Kulrod have sold. Thanks!
    N2YGI likes this.
  9. KA5ILS
    KA5ILS Ham Member QRZ Page
  10. KA5ILS
    I will take the KPC 3 how would you like payment? I can pay by paypal.
  11. QRZ
    Important Rules
    Have you read our Swapmeet Rules?
    This forum enforces a set of buying/selling rules for the benefit of all users. Make sure that you're familiar with the rules before posting or replying in this area. Our moderators review every post in this forum and will flag or delete those that do not conform.
