Choppy audio only on repeater
Discussion in 'Echolink/IRLP Tech Board' started by AF7FQ, Aug 2, 2018.
  1. AF7FQ
    AF7FQ Ham Member QRZ Page
    I had my node up and running with no issues for over a year. I coordinated with a repeater trustee to move the node to the repeater frequency pair and run it as a remote repeater node. Now that I have it on the repeater frequencies, it is giving me problems. The first was that when I connected to the echotest, my node remained in transmit continuously. Changing the serial setting fixed that issue but now when I connect to Echotest and don't transmit anything, my node will key up momentarily about every 10 seconds or so. Also, while in a QSO, the signal coming in from the internet is interrupted about every 30 seconds. It's like the radio stops transmitting for about a half second.
    Has anyone ever experienced these issues? If so, what did you end up doing to fix it? I have wav files of the problems if that would help with troubleshooting.
ad: wmr-1
