ad: Amateur-1
Choosing antenna tuner capacitor
Discussion in 'Radio Circuits, Repair & Performance' started by 9A5DLZ, Feb 16, 2016.
  1. G4LNA
    G4LNA Ham Member QRZ Page
    That's what I do, but I switch the capacitor bank between the input and output, not a PI but a straightforward L match, I haven't found a problem getting a match on any band. You can see that in my diagram in post #32.
  2. 9A5DLZ
    9A5DLZ Ham Member QRZ Page
    G4LNA, I find it difficult to make two coils at exactly the same inductance. For example, two coils that should be 3.2uH are different by 0.05uH. Or maybe 0.01uH. Maybe I am just needlessly obsessing about being perfectly the same?
    I wind them around the pipe, also. And fix them with hot glue.
  3. G4LNA
    I think you are worrying unnecessarily, that sort of inductance would be the inductance of the leads, my coils differ by far more than that and it all works fine. Don't forget that there will be the self capacitance and inductance of the matching unit itself, my unit has a self capacitance of 10pf, I'm not sure of the self inductance I haven't measured it, but there will be some, but it is what it is and I don't worry about it.
  4. 9A5DLZ
    Can anybody recommend some LC meter? I have some chinese meter that I bought from ebay and that one is showing different inductance every time when I measure inductor with it. In the end I had to use theoretical values for inductors, I didn't know which measurement was correct.
  5. K7TRF
    For RF inductors and capacitors I use a grid dip meter or antenna analyzer. Build either a tank circuit (for a dip meter) or a series resonant circuit with one known component and the component under test and find the resonant frequency. Use the dip meter in the normal manner with minimal coupling to the tank circuit or use an analyzer to find series resonance (minimum series resistance, not minimum SWR).
    A good LC bridge is great if you're going to do a lot of this kind of work but if you have some stock of fixed capacitors and inductors of known value you can find unknown RF range L and C values pretty easily.
    -Dave
  6. G4LNA
    I use my antenna analyser, it measures L and C, they are quite expensive but really handy if you are messing around with antennas.
  7. 9A5DLZ
    LC bridge like this?
  8. K7TRF
  9. 9A5DLZ
  10. KL7AJ
    KL7AJ XML Subscriber QRZ Page
    Actually, the inductors don't need to be precisely the same. Even with only moderate matching, you should get a better balance than with any standard balun. I really like this tuner, and I recommend going ahead with it.
    eric
