Choosing antenna tuner capacitor
Discussion in 'Radio Circuits, Repair & Performance' started by 9A5DLZ, Feb 16, 2016.
  1. KL7AJ
    KL7AJ XML Subscriber QRZ Page
    Actually, the T match is fairly universal in A.M. broadcasting...at least here. However, the tuning range is usually very limited, the priority being stability, not flexibility. :)
  2. 9A5DLZ
    9A5DLZ Ham Member QRZ Page
    Yes, my e-mail is correct. Feel free to send it to me, or publish it here so everybody can see it.
  3. G4LNA
    G4LNA Ham Member QRZ Page
    You can say that again, I ended up with 31 relays :eek:
  4. KL7AJ
    The nice thing about teflon sheets is that the increase in dielectric constant lets you use smaller plates. :)
  5. G4LNA
    I will send it to you because this site won't accept xls file extensions.
  6. G4LNA
    That's right and the capacitor Q is much better than using Mica apparently.
  7. 9A5DLZ
    Not a problem, all those relays cost a lot less than a good variable capacitor and roller inductor (if you want to really make a good tuner).
  8. KL7AJ
    Which reminds me....who even sells mica sheets any more? I have some truly ancient ones...I mean TRULY ancient ones....must be near a century old. But I haven't seen them in any catalog for ages!
    K8PG likes this.
  9. G4LNA
    You can still get Mica sheet, I have found somewhere here in the UK that sells it, but Teflon or PTFE is much easier to work with and is cheaper than Mica.
  10. G4LNA
    This is the circuit of the matching unit that sits out in the garden under the open wire line, the controller is in the shack connected to the AMU by a 25 way cable.
    KN4SJE and 9A5DLZ like this.
ad: Amateur-1
