Before I go drop my off center fed dipole to do this, where would the best location for a choke be? Antenna feedpoint or outside shack entry? Both locations? I have 6 mix 31 snap on beads that will fit my coax. Dio I beed more? I would use the nice round donut ones, but I can't solder worth anything, so that is out of the question. I know I could get a inline one, but I am trying to limit the number of connecters in the path. Thanks
Will do. I assume using my 6 sbao on beads would be like wrapping coax though a donut style one 6 times?
Put the choke /balun at the feed point of the antenna. Next put a choke at the point of entry for the house. 61 material? What frequency range are you working on? Usually numerous turns around a ferrite core offer more choking reactance then a few clip on beads. Search K9YC and read his material on chokes. Barry
Not really. When winding a toroid, the ideal impedance goes up by the number of turns squared. So if everything else were equal, 6 turns through a toroid would be equivalent to 36 of your snap on cores. But it isn't nearly that simple in reality. Chances are your snap on beads have a longer magnetic path length than a typical toroid so they may present a higher impedance per turn. Winding capacitance plays a significant role in the broadband effectiveness of a balun as well. To give you a relative perspective, each of your snap-ons will give you less than 300 ohms of choking impedance. A well engineered balun will present greater than 5,000 ohms of choking resistance and an even greater impedance. - Glenn W9IQ
Ahh.. These snap ons can only fit a wire pass each. Can't find the specs on them. I did come across this when looking at options. http://www.ifwtech.co.uk/g3sek/in-prac/index.htm#1005 He uses a larger core snap on and 3 of them wuth looped cable.
The advice you have gotten in this thread is wrong! Most commercial off-center-fed dipoles will not tolerate a Common-Mode-Choke near the feed-point; putting one there will make the antenna useless. These things are poorly designed to include radiation off the coax feedline as part of achieving a match. Even routing the coax down the leg of metal tower will screw them up. I learned all of the this the hard way, as covered in these previous forum threads.
I do have plans to replace the OCF with a fan dipole. But I wanted to relocate the OCF to the backyard as a inveted V due to space restrictions (I still want to have something up that is more multi band than the fan dipole I will have). I guess I could do a dublet for the backard,
With an antenna such as the Butternut HF6V that has a matching section of 75-ohm in series where would you place a choke? At the antenna feedpoint or at the junction of the matching section>feedline?
