Chirp and COM Ports on Mac
Discussion in 'Mac Ham Radio on macOS & iOS' started by KJ4RT, Jul 5, 2021.
  1. KJ4RT
    KJ4RT Ham Member QRZ Page
    I am running Mac High Sierra 10.13.6 and when I try to use it for my TYT TH9800 I do not get Com Port 3 or 4 I only show a bunch of gobbeldigook numbers on the top port and something labeled bluetooth on the next port and I think on the nest on it is something about wireless. I do not see COM port 3 or 4 or anything else.
    Also when I click on the top port and try to click on the window that chooses radio manufacturer it will only stay as long as I keep it clicked and move the mouse pointer to the correct manufacturer, the same thing happens when I try to select the model.
    Any help or suggestions?
  2. KN4QNA
    KN4QNA XML Subscriber QRZ Page
    Mac doesn't handle com ports like Windows. You should see something like /dev/cu.something. /cu.Bluetooth-Incoming-Port and a few others are always present. Look at the list then plug in your programming cable and radio. If the drivers are installed, a new listing will be there and that's the port you need. It should work from there
  3. KJ4RT
    Here is what I get; [Errno 2] could not open port /dev/cu.usbserial-AR0JYZ68: [Errno 2] No such file or directory: '/dev/cu.usbserial-AR0JYZ68'
  4. KN4QNA
    I think that means you have the wrong driver installed or need to reinstall the driver for the programming cable. My experience was with Baofengs and after a few tries it seems to have taken so I am working from 2 year old memories. What cable do you have? I am using the FTDI drivers in my setup
  5. KJ4RT
    The cable I am using for the TYT TH9800 is the one that was supplied by the Manufacturer. The one for my TIDRADIO TH6 the tag says Driver free.
