I travel away from my FCC license home address often and activate at different locations. I have been able to change everything in QRZ successfully (grid, etc) except the county which I have to change manually after a QSO. The ability to change the county is tied to my FCC home address so I only see counties in the State listed as FCC address. What do you all do when you activate away from home address? Am I missing something?
Ok. Thanks to Kaz (JA6XZS) I was able to figure it out. It is a change you make in the logbook settings NOT the callsign settings area. So to update it for a change in location you: Open your Logbook Click on Setteings Click on Logbook Properties Change the address as needed and Click on Set for "USA County:" to select a proper County. Make sure the dates are set correctly then it will change and update correctly when you log. Just have to remember to set it back or to a new location when you move your rig. Thanks Kaz!
