ad: M2Ant-1
CHAMELEON HYBRID SERIES 6M to 160M (1500W SSB)
Discussion in 'Ham Made Gear' started by KI6TRA, Dec 30, 2011.
  1. KI6TRA
    KI6TRA Ham Member QRZ Page
    NEW
    [HR][/HR]
    The Chameleon HYBRID Series is the next generation of Chameleon Antenna. This new generation of antennas and accessories will be fully compatible with almost any previous and future products.
    The Chameleon HYBRID design revolves around a specially designed antenna base: the Chameleon HYBRID Base. This special base offers instantaneous bandwidth performance from 6M to 160M which will depend of the selected antenna configuration. The base is mainly designed to fulfill multiple tasks, enhance performances of the antenna system and facilitate antenna installations. It also has an integral broadband impedance matching allowing broadband waveforms to be utilized even after the addition of higher power amplifiers up to 1500W SSB.
    [HR][/HR]
    With the help of accessories (which are sold separately) the HYBRID base can be converted into four (4) different antenna configuration types:
    1 - END FED ANTENNA (Base kit provided with each HYBRID at purchase)
    The HYBRID End Fed antenna configuration covers 160 to 6 meters without any gaps including WARC Bands, MARS/CAP, 60 meters, etc… The HYBRID End Fed is perfect for apartments, condominiums, homeowners associations, deed restrictions and CCRs (Covenants, Conditions & Restrictions), First Responders, Emergency Preparedness, attic antenna installation, back packers, RV antenna, field day operation, portable installation, stationary vehicular installation, sail boats and many more. The biggest advantages of the End Fed configuration is that the HYBRID doesn't required any ground connection for great performance. The configuration types for the End Fed HYBRID are numerous: vertical, sloper, horizontal, inverted "L", inverted "V", zig-zagged, etc...
    [HR][/HR]
    [TABLE]
    <tbody>[TR]
    [TD]MSRP: $225
    [/TD]
    [TD]
    [/TD]
    [/TR]
    [TR]
    [TD]
    [/TD]
    [TD]
    [/TD]
    [/TR]
    </tbody>[/TABLE]
    [TABLE]
    <tbody>[TR]
    [TD]
    ELECTRICAL SPECIFICATIONS
    [/TD]
    [/TR]
    </tbody>[/TABLE]
    [TABLE]
    <tbody>[TR]
    [TD]
    [/TD]
    [/TR]
    </tbody>[/TABLE]
    [TABLE]
    <tbody>[TR]
    [TD][/TD]
    [TD]
    [/TD]
    [/TR]
    [TR]
    [TD]
    Frequency:
    [/TD]
    [TD]6M - 160M
    [/TD]
    [/TR]
    [TR]
    [TD]Power:
    [/TD]
    [TD]1500 W SSB
    [/TD]
    [/TR]
    [TR]
    [TD]RF Connection:
    [/TD]
    [TD]SO-239
    [/TD]
    [/TR]
    [TR]
    [TD]Input Impedance:
    [/TD]
    [TD]50 Ω
    [/TD]
    [/TR]
    [TR]
    [TD]VSWR:
    [/TD]
    [TD]Subject to configuration
    [/TD]
    [/TR]
    [TR]
    [TD]Pattern:
    [/TD]
    [/TD]
    [/TR]
    [TR]
    [TD]Polarization:
    [/TD]
    [TD]Linear
    [/TD]
    [/TR]
    [TR]
    [TD]Height:
    [/TD]
    [TD]30’
    [/TD]
    [/TR]
    [TR]
    [TD]Weight:
    [/TD]
    [TD]3 Lb.
    [/TD]
    [/TR]
    [TR]
    [TD]Mounting Configuration:
    [/TD]
    [TD]3/8-24 Thread
    [/TD]
    [/TR]
    </tbody>[/TABLE]
    [HR][/HR]
    HYBRID Base End-Fed setup from KF7PDV (RACES Event) - SWR < 1.2:1 on 80M & 40M with antenna tuner - About 300 miles communication radius
    [HR][/HR]
    2 - VERTICAL ANTENNA - VEHICULAR MOBILE (COMING SOON)
    The HYBRID vertical vehicular mobile whip antenna is designed to enhance the radio communication application capabilities across the entire HF band. The 9'5" antenna whip is composed of two screw together sections: 5' fiberglass section and a 4'5" stainless steel section. Those two sections are mounted on top of the spring HYBRID base. For stationary vehicular operation the Chameleon MIL Whip (10'8") can be added on top of the 5' fiberglass section to improve communication performance while the vehicle is stationary and doesn't move.
    [HR][/HR]
    3 - VERTICAL ANTENNA - BASE STATION
    UNDER CONSTRUCTION
    [HR][/HR]
    4 - DIPOLE ANTENNA - ALL BANDS + NVIS
    UNDER CONSTRUCTION
    [HR][/HR]
    OPTIONAL ACCESSORIES
    • Capacitance Hat
    • Tilt Whip Adapter
    • Portable Collapsible Mast
    • Portable Collapsible Aluminum Heavy Duty Antenna for FIeld Operation & Base Station for High Power (1500 W)
    • Counterpoises ring and wires + Stakes (Pack of 4)
    [HR][/HR]
    HYBRID DESIGN & PRODUCTION OBJECTIVES FOR 2012
    The following are our HYBRID DESIGN & PRODUCTION OBJECTIVES for 2012. What you're about to see are only concepts and ideas that we're working on at the moment. Everything is at the design & conceptualization phase: (What you see wont be exactly at its represented on the drawing.) NO DATES ARE AVAILABLE AT THE MOMENT.
    A - HYBRID Antenna Tilt
    B - HYBRID Antenna Tilt rotating from 0 to 90 degrees.
    C - HYBRID Antenna Tilt with collapsible 24' vertical antenna for base station (1500W)
    D - HYBRID Antenna Tilt for V1, V2L, V3, MIL Whip antenna, etc... Use for bumper or special tripod mount.
    E - HYBRID Antenna Tilt with mast extension for V1, V2L, V3 antenna, etc... Use for bumper or special tripod mount.
    F - HYBRID Antenna Tilt with collapsible 15' mast extension for dipole wire setup & NVIS
    [HR][/HR]
    Chameleon HYBRID Base + MIL Antenna on a Bicycle
    [HR][/HR]
  2. WA4QKV
    WA4QKV Ham Member QRZ Page
    Do you have a price list for the antennas you sell?
    Thank you!
    Jim WA4QKV
  3. KI6TRA
