Another efficient portable easily deployable addition to my go bag which is an add-on to the Chameleon MPAS 2.0 antenna system, OR can be used by itself.
I have a CHA TDL incoming to me now. Hopefully it will arrive in the next couple days. I do have a question though, I know you want to use a 25' counterpoise if you are using it as a ground mounted vertical, but I saw a video of someone using the CHA TDL ground mounted with about 8 or so radials. So my question is, since you have some time using this, do you see a benefit of making of about 8 25' counterpoise/radials when the TDL is in Delta Loop mode? Nothing in the manual suggests needing radials in that mode.
