Can I mount 2 Antennas on a single mast?
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KC1LXL, Oct 30, 2020.
  1. KC1LXL
    KC1LXL Ham Member QRZ Page
    Hello,
    Still learning this great hobby, but wanted to ask opinions on mounting two antennas on the same mast. I have spoken to a few folks and views are differing on the subject. I have a multi-band radio with dual antenna inputs. I own a GP-6 vertical antenna mounted on an eave mount to provide me 146 MHz and 446 MHz frequencies. The antenna is clamped on metal mast.
    I also want to eventually enjoy HF, so I have a CHV-5X multi band dipole which I will mount either in a V or horizontal position
    Ideally, I would like to mount both antennas on the same mast... the vertical up top and the horizontal below. Is this possible? Would there be interference issues even though only one antenna would be in operation at a time. I have a longer mast if spacing needs to be maintained.
    Thank you
  2. KA9JLM
    If they are different in polarity, It should not be problem.
    Vertical Antennas side mounted below the top of the mast can have weird directional patterns.
  3. KL7AJ
    KL7AJ Ham Member QRZ Page
    But also, possibly some very useful directional patterns.
    KA9JLM and AK5B like this.
  4. KB1CKT
    KB1CKT Ham Member QRZ Page
    The dipole looks like a horizontal one to me. If the mast can take the weight then I don't see an issue here. Only if you were putting up a wire dipole fed with window or ladder line would you have a problem with the feedline coming down (can't tape to the mast).
  5. N7WR
    Done it many times. Should not be a problem. The VHF/UHF antenna should not interact with an HF antenna or vice versa. Separate the two by a couple of feet vertically and you should be good
