Callsigns in QRZ data bank not recognized by HAMRS, now what?
Discussion in 'QRZ Site Community Help Center' started by DA6HC, Feb 1, 2026.
  1. DA6HC
    DA6HC XML Subscriber QRZ Page
    Ladies and gents,
    for POTA activities, I'm trying to set up HAMRS to integrate with QRZ. My idea is obviously to get the correct callsign from QRZ into HAMRS. And yes, I did input the correct API key in the integration set-up, and yes, I have a valid QRZ XML subscription plan.
    Now, while the callsigns are posted correctly in QRZ, in each attempt to set up a new log in HAMRS, the log "in process" replies "QRZ.com call no found. No callsign found for ::::::"
    What am I doing wrong? Any help is greatly appreciated!
    Thanks and 73 from Germany,
    Chris
  2. KF8KI
    KF8KI QRZ Staff Engineer QRZ HQ Staff QRZ Page
    This sounds like a HamRS configuration error. Can you provide some screenshots of the error messages you are getting?
    73, Steve KF8KI
  3. DA6HC
    Steve, thanks for looking into this!
    Yep, this is a screenshot of my today's attempt to update the log, check out the red field top right hand corner. The call LAIWWA is valid and working, but as you see, no transfer of data. In the lower half of the "log attempt" you'll find the same thing, three unconfirmed calls
  4. W7UUU
    If you would enter the call sign correctly, you will probably get a better result.
    It's not "LAIWWA" - it is "LA1WWA". There's a difference
    Dave
    W7UUU
  5. KF8KI
    LAIWWA isn't a valid callsign. That would certainly generate an error.
    I'm not sure I understand your explanation. Are you saying GB2WWA and TM7WWA are generating errors as well?
    73, Steve KF8KI
  6. DA6HC
    Steve, Dave,
    sorry, have indeed mis-spelled. However, that's not where the problem lies, since the other calls including their correct numbers will appear - or rather not appear - in the same fashion:
    Hm, any idea? Thanks!
  7. KF8KI
    @DA6HC
    When external software does a lookup from QRZ, it uses our XML interface. We have a test tool you can use to see exactly what is returned when doing a lookup via that interface. Here's the link. Log in there with your QRZ credentials and lookup the callsigns you are having issue with.
    https://xml.qrz.com/xcheck
    Each one of them is a valid callsign that we are returning a record for. I've verified each myself.
    I don't know what problem HamRS is having getting the information, but I'm afraid you're going to need to contact them to determine what the problem is with the software. We are properly returning records for those callsigns. Sorry to play "pass the buck"
    73, Steve KF8KI
  8. KP4SX
    What's the 2200m band in your log?
