Callsign Variations.
Discussion in 'QRZ Site Community Help Center' started by M0NBR, Nov 24, 2024.
  1. M0NBR
    M0NBR Premium Subscriber QRZ Page
    I look after the Club Callsigns.
    I have entries for G4OO which has also operated as GX4OO, GQ4OO plus Portable Variants.
    Is there a way for these all to be entered under the one G4OO Callsign?
    Regards.
    Alan.
  2. KX0DW
    KX0DW QRZ Lifetime Member #212 Volunteer Moderator Volunteer DX Helper Platinum Subscriber Life Member QRZ Page
    As these are Club Callsigns, they have to be managed by someone and cannot serve as managers for each other. I see that you have G4OO and GQ4OO already setup under your primary M0NBR account. You can add GX4OO as another managed callsign under your account and they'll all be there. If you are running out of "space" in your managed callsigns (ie, you have more than 4), submit a trouble ticket at https://ssl.qrz.com/support to request that the limit be increased for your account.
    As far as portable versions, you should be able to go into each of these callsigns and setup Portable variants using the normal means. For example, if you're wanting to edit G4OO:
    Go to https://www.qrz.com/db/G4OO
    Click the "G4OO" in the upper right corner of the menu bar
    Select Edit G4OO
    Select "Add a special callsign such as G4OO/MM, G4OO/P34, etc"
    Select "Non-DX modifier (such as /R /M /P /QRP, etc)
    Place the "P" in the field right after the big G4OO/ located just a bit further down the page, and then save.
    Do this for each of your managed calls and you should have them all in the system.
ad: Radioddity-1
