Cables, Portable Power, and More Cables!!!
Discussion in 'Ham Made Gear' started by K0LTZ, Mar 30, 2019.
  1. K0LTZ
    K0LTZ Ham Member QRZ Page
    Greetings all from K0LTZ! It has been quite some time since I posted here, and I have new product offerings. I have great capabilities in making custom coax, power, audio, and other cable assemblies and wiring harnesses. I am now introducing portable 'GO' power packs which are highly customizable, rugged, 12v nominal battery powered supplies using AGM or LifePO4 cells. I can create assemblies and cables using Anderson PowerPoles, Molex, AMP, etc. I can print heat shrink labels. I have all the specialized tools, connectors, wire, cable, and coverings in stock. Let me know your needs and let me serve you.
    Cables are generally quoted based on a number of factors, length,cost of parts, difficulty, etc. however I make every attempt to be reasonable and competitive.
    Power 'GO' boxes start at 79.95 and include 1 set of black/red binding posts, and 1 Anderson PowerPole jack with wiring and contacts rated for battery Ah size intended for use (ie. 12Ah box uses 15A terminals, 20Ah box uses 30A terminals). Basic boxes are sold less battery or charger. Additional switches, volt meter, USB, cigar lighter, etc panels as well as batteries and chargers are available.
    Small size battery box is 11.625 x 5.125 x 7.125 inches, and is recommended for up to a 15Ah AGM or 20Ah LifePO4. Starts at 79.95.
    Large size battery box is 15.00 x 8.00 x 10.00 inches, and is recommended for up to a 26Ah AGM or 40+Ah LifePO4. Starts at 119.95.
    Although I am not a "business", I call my venture "Ham Power Gear" and can be contacted directly, without hassle, at HamPowerGear@gmail.com.
    20190324_120924.jpg 20190324_120942.jpg 20190324_121349.jpg 20190324_121354.jpg 20190324_121405.jpg 20190324_121412.jpg 20190324_121431.jpg 20190324_121437.jpg Plano_13131252.png Plano_16161250.png
ad: GNOHF-1
