ad: wmr-1
BUILDING FAN DIPOLE OUT OF RG58 COAX ?
Discussion in 'Ham Radio Discussions' started by K5FRH, Jan 18, 2019.
ad: QSOToday-1
  1. K5FRH
    K5FRH Ham Member QRZ Page
    In looking around my shop to see what "surplus" wire I have in enough length to use for a fan dipole, I have several hundred feet of RG58 on a spool that I picked up at a garage sale for a very minimal cost. I am thinking about using it for an 80/40/20 fan dipole.
    I would like opinions as I may be overlooking something. For instance, if I short the center conductor to the shield on both ends of the coax and also where each piece terminates into the center feeder point, that should make each length of coax just one long wire....correct ? So not dealing with impedance or shielding issues.
    Also, what about building/winding my "ugly balun" also out of RG advice.58 instead or Rg8 as most articles demonstrate. I would still use RG8 as the feeder from transmitter to balun.
    I know I might pick up a little more wind resistance and weight than just using 14 gauge stranded wire,.
    Thanks for your opinions and advice.
  2. NL7W
    NL7W Ham Member QRZ Page
    Too heavy.
    K7TRF likes this.
  3. NN4RH
    Copper is copper, even if it's coax.
    But as you note it will be heavier than just wire.
  4. KE4OH
    KE4OH Ham Member QRZ Page
    Sounds like a good plan to me! It will be heavy, though. But so what? Back in the day, a lot of guys built double bazooka dipoles out of coax and they mostly stayed in the air.
  5. KP4SX
    IF its a good heavy copper braid then it should hold up ok. Now if its aluminum foil and a few strands the stretching will possibly break it.
  6. N2EY
    N2EY XML Subscriber QRZ Page
    I wouldn't.
    The weight and wind loading are excessive. You'd be better off using "house wire".
    Electrically, it's fine. Mechanically.....not so much. In amateur radio, antenna design is mostly mechanical design.
    K7TRF likes this.
  7. WD8T
    WD8T XML Subscriber QRZ Page
    It several hundred ft of RG-58 is what you have then use it. As has been said it will be heavier and it may also be a bit of a headache to tune so I hope you have an analyzer to help. Do you plan on putting it up as a flat top or inverted V? Installing as an inverted V would be better in terms of supporting the center of the antenna because of the extra weigh of the coax..
  8. K4PIH
    K4PIH Ham Member QRZ Page
    I'd go to Home Despot and pick up a 500' role of THHN coper clad stranded insulated wire and build the fan out of that. Save the COAX for the feed run. The wire is around $50, lighter, cheaper, easier to handle than the 58.
    If you just have to get ride of the RG58 for free, my address is good.:)
    K7TRF likes this.
  9. KC8VWM
    KC8VWM Ham Member QRZ Page
    It's good for making buried radials for vertical antennas.
    Might be okay for making a single band antenna anywhere from 20-10m , but using it to construct a fan dipole is going to present some physical installation challenges.
    In terms of using feedline to construct Ugly Baluns, they are not effective over a wide range of frequencies. Typically these are only used on a single band antenna design and for everything else where choking common mode current is required over a wider range of HF frequencies, ferrite core material is your friend.
    K7TRF likes this.
  10. K5FRH
    thanks
ad: vanity
