Building 6M 4El CUBICAL QUAD ANTENNA
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by W5ZZ, Aug 1, 2020.
  1. W5ZZ
    W5ZZ Ham Member QRZ Page
    Hello everyone,
    Want to built 6 meter 4el cubical quad on a 8 ft boom , so I found this online calculator:
    https://www.qsl.net/yt1vp/CUBICAL QUAD ANTENNA CALCULATOR.htm
    Is anybody used it? Is it a good and accurate ?
    Another question : - If I use 14 AWG THHN wire , do I need to reduce wire dimension of 5% ?
    Thanks
    Serge
    W5ZZ
  2. WA4SIX
    WA4SIX Ham Member QRZ Page
    I am not sure if 4 elements on that boom length is worthwhile. Try modeling it with 2 & 3 elements first. Gain usually has more to to with boom length, than elements.
    Ed
    AK5B, W5ZZ and AD5HR like this.
  3. W5ZZ
    I got a 2 el quad already , works good, but want more gain :)
  4. WA4SIX
    What is the boom length of the 2 element?
    Ed
  5. WB2WIK
    4L on 50 MHz, 8' boom is "boom length limited."
    Extra elements don't add the gain; spacing between them does. 4L would have good gain with about a 13.5' long boom.
    W5ZZ likes this.
  6. W5ZZ
    If I remember right, about 45"
  7. W5ZZ
    I thought multiple parasitic elements that what add gain, and a proper spacing between then makes gain even greater.
  8. AK5B
    AK5B Ham Member QRZ Page
    Only if the boom is longer for the proper spacing allows greater gain. Add all the elements you want to a short boom Yagi and nada more gain. One needs both to effect the desired change.
    W5ZZ likes this.
  9. KM1H
    KM1H Ham Member QRZ Page
    4 el about 12'
    5 el about 17'
    6 el about 24'
    A quad offers nothing special over the narrow active part of 6 and a yagi is often easier to build and tune.
    My current version is 8el on a 35' boom
    Carl
    W5ZZ and AK5B like this.
  10. WB2WIK
    Yep.
    Charge acceleration. And that doesn't occur with a bunch of closely spaced elements.
