Best amp for beginners
Discussion in 'Amateur Radio Amplifiers' started by WW4LS, Apr 12, 2021.
ad: QSOToday-1
  1. W4NNF
    W4NNF XML Subscriber QRZ Page
    Be aware....while some have good luck with the MFJ solid state amps, many do NOT. Take a stroll through eHam, maybe. My feeling is that if you want reliability in a solid state amp, you need to think "top of the line" or at least the next tier above MFJ. If you want to stay in their price range I advise sticking to their tube amps. ;)
    KD2ACO likes this.
  2. KD2ACO
    @WW4LS
    I think I'd avoid 811 or even 572b amps now because of fragility (811) and just not having good tubes to source (572b).
    This leaves the 3-500 as an output device with the best 'fire in the wire' for the money. That tube can take a mistake and not burn up.
    If the antenna is set up decently. you won't need a tuner.
    WW4LS likes this.
  3. W4NNF
    The 811s can definitely be OK if they are treated gently. They are, however, not the tubes they were when they were produced in the U.S.; some of these Chinese tubes WILL flash over no matter what you do. Luckily, they are inexpensive. ;)
    WW4LS likes this.
