baofeng uv5r impossible to program?
Discussion in 'General Technical Questions and Answers' started by W9WQA, May 12, 2019.
  1. W9WQA
    W9WQA Ham Member QRZ Page
    using keyboard? can you bring up a repeater. im reading the words off the pages of the much abbreviated"instruction"pamphlet,CANNOT get 600000 offset,
    i get 476 mhz? trying to hit a local 2 meter rptr.
    i ordered the cable but tried to download the "free " chirp. no such thing as free,GOTTA make donation!!
    i d send a check but dont want to use a credit card/paypal to ???
    btw i find the uv5r to be good looking,hefty for small ht, super styled, looks like tough miletary stuff,
    great battery,nice multi color recessed display, nice voice feedback,actually ez to find menu stuff, a really nice ht,and a super price, BUT I CANT MAKE IT WORK.
    anyone get a decoder ring to work with the 40 step menu?, then the 10 or so steps that follow the 40 and then,,,end??? leaving me hanging...
    step by step please,get me into 146,775,down 600,pl 131.8...
  2. KM4MIS
    KM4MIS Ham Member QRZ Page
  3. W7UUU
    W7UUU QRZ Lifetime Member #133 Administrator Volunteer Moderator Platinum Subscriber Life Member QRZ Page
    Google it. There are a number of sites that have decoded the evil Chinglish Baofeng manual for mortals to program.
    I know a disabled ham with no use of his hands and can program a UV5R with just his tongue and teeth - true story.
    Just Google it - there are lots of "plain English" programming guides.
    Dave
    W7UUU
    K9ASE likes this.
  4. KM4MIS
    Programming link and simple programming example you requested for channel 99.
    Change 99 to any open channel or delete existing channel as in line 4.
    http://www.miklor.com/COM/UV_ProgMem.php
    1. Set radio to Frequency Mode (VFO)
    a.) UV5R - Press VFO/MR button
    b.) UV82 - Press/Hold MENU button during PowerON.
    2. Select Upper Display
    a.) UV5R - Press [A/B] and select the Upper Display.
    b.) UV82 - Press [EXIT A/B] and select the Upper Display.
    3. Turn TDR OFF (Dual Watch)
    [Menu] 7 [Menu] OFF [Menu] [Exit]
    4. Delete Prior Data if channel is not empty.
    [Menu] 2 8 [Menu] 9 9 [Menu] [Exit]
    5. Set TX CTCSS / DCS codes for Transmit. (optional)
    [Menu] 1 3 [Menu] up button to 131.8 [Menu] [Exit]
    6. Store RX frequency into channel
    1 4 6 7 7 5 [Menu] 2 7 [Menu] 9 9 [Menu] [Exit]
    7. Store TX frequency into channel
    1 4 6 1 7 5 [Menu] [Menu] 9 9 [Menu] [Exit]
    Switch back to Channel Mode (MR)
  5. W9WQA
    tried 3 times, closer but no shift, must be step sequence,ill try tomorrow,BIZZARE.
    THANKS, i get the idea,just cant get it right???
    wont xmit in freq mode.
    goto ch mode,xmit on495??mhz?? no 600 shift..
    in menu yesterday i entered 600kc offset,"-" shift...why??? not used?
    tried again on 146970/370. always xmit on 496?mhz appx on ch mode
    freq mode shows 146370,wont xmit.
    ch mode shows 146970, xmit on 400mhzappx,never down 600
    ga nite
  6. KM3F
    KM3F Ham Member QRZ Page
    Are you using a shift value of - .600 not 600 or 60000 or any other sized number?
    146.970 minus .6 = 146.370. Remember your programming the processor to shift the VFO - 600 khz upon transmit and send a tone to unlock the repeater receiver so you can talk through the repeater.
    The shift has to be negative. Then add the PL tone.
    Then commit to memory.
    On any normal radio that's all there is to it.
    Don't need any computer or cables to do this.
    Look at the keys and find out what does the functions. It's the same for any analogue FM radio.
    Why is this so difficult?
    Understanding the process leads you to do it.
    Good luck.
  7. W9WQA
    i should have said ive been running hts for 30 yrs, have 5 others that i dont need !! i got this as a toy,and 20 bucks i can toss. yes i know about -+ shift and 600 kc offset.
    why did i enter them and athe ALSO rec and xmit freqs??
    "Why is this so difficult?" thats what i say !!!
    i do appreciate help but this IS difficult...
    did you guys actually decipher the methode from the "instructions" or other help..?
    ex: where does it say ".600: and not 600000.
  8. WA4BCS
    WA4BCS XML Subscriber QRZ Page
    Chirp is freeware.
  9. K7MH
    K7MH Ham Member QRZ Page
    Yes. It does ask for a donation but it is not required.
    The OP needs to navigate the CHIRP website a little more than he did.
    WA4BCS likes this.
  10. WA8UEG
    I have a Woxun, I figured it out with much difficulty but the next time I want to add or change something I have to go through the whole learning process again. Very simple solution that is worth every penny is the programming software. Makes programming or changing anything very quick, very easy .
