Baofeng uv-5r tx-ab menu option function
Discussion in 'Mobile Radio Systems' started by LU8DST, Jan 13, 2020.
  1. LU8DST
    LU8DST Ham Member QRZ Page
    Hi All. I have Baofeng UV-5R (controvertial I know) and I don't found what is the function of tx-ab menu option. I have active the dual watch reception but I don't see any change in the behabior using this option. Have any same info? Thanks. 73.
  2. ND5Y
    ND5Y Ham Member QRZ Page
    Do you mean Menu 34 TDR-AB?
    If so then read the menu definitions at http://www.miklor.com/uv5r/UV5R-MenuDef.php.
    It does nothing unless you have Menu 7 TDR turned on.
    I read someplace that TDR-AB does different things in different firmware versions.
  3. LU8DST
    Yes I refer to Menu 34 TDR-AB. I have Menu 7 TDR turned on but doesn't do any different selecting option. I read the manual but is not helping me. Thanks. 73.
  4. KF5FEI
    KF5FEI Ham Member QRZ Page
    I seem to recall, when you have the radio set to switch back and forth to listen to two different frequencies, the other setting determined if the A (top) frequency or B (bottom) frequency was the one you transmitted on.
  5. LU8DST
    I think that this is the idea but in my HT don't happend. Do you see this behavior in your HT? Thanks for reply. 73!
  6. KC9ONY
    KC9ONY Ham Member QRZ Page
    This is the way it works on my UV-5R+Plus with Firmware version BFB293,
    as shown on the display. I have not checked the Firmware version in CHIRP.
    http://www.miklor.com/uv5r/UV5R-FWRelease.php
    With Menu 7 TDR set to ON, and Menu TDR-AB set to OFF:
    Whichever side receives a signal, it will stay on that side to enable me to transmit a reply.
    So, if it's listening to the A side and receives on the B side, it will stay on the B side,
    so I can respond on the B frequency.
    I can use the A/B button to switch between A side or B side.
    With Menu 7 TDR set to ON, and Menu TDR-AB set to A:
    If I receive a signal on the B side, it will automatically switch back to the A side to transmit.
    Thus, I can only transmit a reply on the A side.
    Using the A/B button will always go back to the A side.
    With Menu 7 TDR set to ON, and Menu TDR-AB set to B:
    If I receive a signal on the A side, it will automatically switch back to the B side to transmit.
    Thus, I can only transmit a reply on the B side.
    Using the A/B button will always go back to the B side.
    Hope this makes sense to you.
  7. KC9ONY
  8. LU8DST
    Thanks all for the reply. I have Firmware version BFB298 and the answer to my question is
    "TDR-AB function simply no longer worked"
    Thanks. 73!
