ad: portazero-1
Balun or No Balun on 80 meter loop?
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KC8PJS, Nov 14, 2009.
  1. NL7W
    NL7W Ham Member QRZ Page
    If possible, skip the introduced balun and coaxial losses and run balanced feed-line. That's easy enough... been doing that for years and years at my own station.
    The reason I said this is to show that the use of such a feed method can be put to efficient use with a balanced antenna -- like the high 80 meter loop I built and used to WIN and set a NEW RECORD in a highly competitive U.S. contest -- Sweepstakes. Example: a 1/3 wavelength high loop presents an impedance peak, in relation to "ground," at around 165 ohms or so.
    The 4:1 balun transformation and coax use method does work -- and work well -- if the antenna's design and it's environment present a matching impedance.
    You've have to know what you're up against... ahead of time. I work that way.
    Yet, generalized assumptions can be made, and a case developed around them for such certain "multi-band" antennas -- as in your case.
    Merry Christmas!
