Anybody Interested in Upcoming IC-9700
Discussion in 'Satellite and Space Communications' started by W5SAT, Mar 20, 2018.
  1. KB1PVH
    KB1PVH XML Subscriber QRZ Page
    From what I understand Ray Novak from Icom said they are working on the stability issue.
  2. WA7F
    Good to hear. Thanks.
  3. WA4SCA
    WA4SCA XML Subscriber QRZ Page
    From one of the IC-9700 lists:
    Hi all,
    i just got the information from Icom Europe that the drift-problem is fixed.
    We just have to wait for the next FW releases. It will be available soon, no fixed date given.
    No Information how they fixed it and how the implementation will work yet.
    I will share my results soon, i think that are really good news ;o)
    Many thanks to the technicians from Icom in Bad Soden who had an open ear for me!
    Michael
    DL5OCD
    No idea about this beyond Michael's posting. Hopefully it will be an engineering fix, not a marketing fix. :)
    Alan
    WA4SCA
  4. WA2LXB
    WA2LXB Ham Member QRZ Page
    TCXO 10MHz input port would have been the shizzle...or better yet, an onboard TCXO with GPS antenna port :)
    KO4MA likes this.
  5. KO4MA
    KO4MA Ham Member QRZ Page
    Along with a row of separate RCA jacks for amp keying. Such a simple thing that would make things easier for everyone.
    WA4SCA and WA2LXB like this.
  6. WA7F
    It almost sounds like their heads were wrapped around FM and Digital more than SSB.
  7. WA4SCA
  8. WA4SCA
    SatPC32 now officially supports the IC-9700.
    From the AMSAT-BB mailing list:
    Hi
    Yesterday I uploaded a file with instructions on how to configure the
    IC-9700 and SatPC32 for CAT control (English page 'Downloads')
    http://www.dk1tb.de/IC9700_settings.htm
    All CAT features seem to work flawlessly. I tested the CAT control
    several hours straight without any problem.
    Also, I uploaded revised files that add the IC-9700 to the lists of
    supported models (with the recent program file choose the IC-9100 as
    model. That will work also because I did not make any other changes to
    the program code).
    The German text can be downloaded here:
    http://www.dk1tb.de/IC9700_settings_dt.htm
    Thanks to LA7XK and others who helped to find out and test the settings.
    73s, Erich, DK1TB
  9. KG6TR
    KG6TR XML Subscriber QRZ Page
    Curious if anyone has run this with an Arrow 146-437/10 antenna. Interested in SSB, seems like a good one-antenna solution for 2m/7cm, can run the 2m horizontally polarized with 70cm vertical for local FM.
  10. W5SAT
    W5SAT Ham Member QRZ Page
    Yep - there is a new version of SatPC32 dated June 7. It has some other improvements as well - most obvious is that you can have 24 satellites available to choose from at a time instead of 12. Nice!
    Seems to work fine with IC-9700. Bummer that SatPC32ISS is still not working correctly with the IC-9700.... :(
