ad: AlphaRF-1
Antenna Tuner
Discussion in 'General Technical Questions and Answers' started by SV1DUE, Mar 1, 2021.
  1. SV1DUE
    SV1DUE Ham Member QRZ Page
    Good evening to everyone from Greece
    Please does anybody know what's the difference between this :
    ATU100 Automatic Antenna Tuner 100W 1.8-30MHz Assembled For 5-100W Shortwave Radio Stations ATU-100
    and this one:
    New ATU100 Automatic Antenna Tuner 100W 1.8-30MHz With Battery Inside Assembled For 5-100W Shortwave Radio Stations
    and finally this:
    New ATU100 Automatic Antenna Tuner 100W 1.8-55MHz/1.8-30MHz With Battery Inside Assembled For 5-100W Shortwave Radio Stations
    I found all three of them
    on an international e-shop platform. Because I'm setting up my Ham radio station in this period, I would appreciate any answer.
    Many thanks 73s SV1DUE
  2. W4HWD
    W4HWD Premium Subscriber QRZ Page
    #3 is the cutest.
  3. SV2HZF
    SV2HZF Ham Member QRZ Page
    They're all pretty much the same; Chinese garbage.
    I had once bought one from eBay and it soon went in the trash. Low Q coils, terrible quality caps and relay switches, awful firmware;
    If i were you i wouldn't spend a dime on these. Save your hard earned money for something that is worth it.
    73s
  4. SV1DUE
    Ευχαριστώ για την απάντησή σου. Ναι, τελικά αμφιβάλλω πολύ αν θα το παραγγείλω. Πάντως ευχαριστώ. Ερώτηση. Η χρήση εθνικών Γλωσσών δεν επιτρέπεται και γι΄αυτό μου απάντησες στα αγγλικά; Είμαι καινούργιος στο QRZ και δεν γνωρίζω τη δεοντολογία. 73ς Χρήστος
  5. SV2HZF
    Ναι, η αλήθεια είναι πως ενοχλεί αρκετά και αρκετούς εδώ η χρήση άλλης γλώσσας Χρήστο.
    Τα 73 μου, Θάνος
  6. K8JD
    K8JD Ham Member QRZ Page
    I prefer a maual tuner, at least if it bereaks I know I can fix it.
  7. AC2RY
    AC2RY Ham Member QRZ Page
    If you need a remote tuner (it means your antenna presents more than 3:1 SWR and internal tuner in transceiver cannot handle it), you better get REMOTE tuner and place it NEXT TO antenna. The best tuner for 100W of power is ICOM AH-4.
  8. SV1DUE
    Ok, only in ENG from now on. Thanks a lot for your answers.
  9. KK4NSF
    KK4NSF Ham Member QRZ Page
    Doesn't bother me at all. In fact, Greek is a great language in which to converse. There is no rule, written or otherwise that says you can't use it. The only problem I see with it on this forum is that many can't speak / read / write it here in the US. BUT that is easily overcome with a computer.
    About the tuner: I don't know anything about the three you mention. BUT I do like the MFJ 971 Portable. It works well, and is easy to tune. If there is a vendor new you, it could be a good option.
    SV1DUE and SV2HZF like this.
  10. SV1DUE
    KK4NSF, ευχαριστώ πολύ (efcharisto poly) ! which means thanks a lot.
ad: portazero-1
