Antenna plans that don't make any sense.
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KC8VWM, Nov 14, 2011.
ad: QSOToday-1
  1. KC8VWM
    KC8VWM Ham Member QRZ Page
    Thes swr is excellent on all bands
  2. AE7F
    AE7F Ham Member QRZ Page
    Very helpful thread. I'm still waiting for my 6-way hub.
  3. AK5B
    AK5B Ham Member QRZ Page
    Charles, can you confirm that the actual length of the spreaders (not the feedpoint arm) is somewhere around 6-6 1/2 feet out from the center of your hub?
    I've been looking through all the different cobwebb sites trying to determine the actual spreader length needed and I mostly find element length info instead.
    I have my 9' poles on the spider now and I just realized I may very well get by with another 3' section removed if this 6' + measurement is correct (Mine are mounted on short PVC arms on my 12" square plate so 6 feet of fiberglass should work out to around 6' 4" spreader length total). If so this would be great as it would be more compact and lighter; my "MIL SPEC" version is getting heavy!
    Thanks!
    73, Jeff (with cobweb in progress; been working on the balun today...)
    G1YBB likes this.
  4. G3TXQ
    G3TXQ Ham Member QRZ Page
    Jeff,
    On my cobweb the 20m wires are attached at a distance of 72.25" along the spreaders from the centre of the hub; there will be some slight variation depending on the wire type you use and its velocity factor.
    Steve G3TXQ
    G1YBB likes this.
  5. AK5B
    Thanks, Steve; inasmuch as I'm using the same type of wire 1mm/2mm insulation as you it appears that I'm good to go with the 6 footers plus a tiny bit.
    Cheers, mate!
    73, Jeff
  6. KC8VWM
    Yup, 6-6 1/2 feet is just fine. Anything longer is just extra. Good luck with the project Jeff.
  7. AK5B
    Thanks, Charles; That's really good news.
    Today I'm winding the balun cores and it's going smoothly so far. I'll post more pix on my DIY cobweb thread again soon.
    73, Jeff
  8. KC8VWM
    I think I am just as excited to see it in the air as you are..:) I will stay tuned.
