Ampersand Breaks QRZ Upload from HRD
Discussion in 'QRZ XML Logbook Data' started by N9AED, Sep 2, 2021.
  1. N9AED
    N9AED XML Subscriber QRZ Page
    In HRD, if I use an ampersand (&) in the Comments field, and upload the log entry to QRZ, QRZ rejects the upload: "missing <EOR> in record".
  2. KA9JLM
    Special charters are best left out of a somewhat plain text file.
    Many times you can put a entry in quotes " This is a test & it worked" To avoid a EOF or EOR errors.
    The "&" screws with the End Of Record in your case. A Under Score _ works for me to add comments, Even in a file name.
    Good Luck. The structure if a ADIF file seems to be well documented. Maybe a update is in order ??? But it does work As Is for most users.
