Amp repair service
Discussion in 'Amateur Radio Amplifiers' started by KF7PK, Nov 6, 2019.
  1. KF7PK
    KF7PK Ham Member QRZ Page
    I have an amp supply LK500ZC that needs repair. Anyone know where I could get it repaired
    Chuck KF7PK
    Don't know anyone around eastern Oregon.
    If you're willing to pack and ship, there are plenty of places, including one who posts here regularly from Connecticut.
  3. WA7PRC
    WA7PRC Ham Member QRZ Page
    That would be Lou, @W1QJ. He does A LOT of repair & 6m conversions. :)
  4. W1QJ
    W1QJ Ham Member QRZ Page
    No problem on that. It is a long haul unfortunately but it would not be the first time I had amps sent from the far end.
    WA7PRC likes this.
  5. N8FVJ
    N8FVJ Ham Member QRZ Page
    What do the amp do? Simply blow the fuses (CBs)?
  6. KF5LJW
    KF5LJW Ham Member QRZ Page
    Agree, what is wrong?
    There is not much to that amp. Should be a simple fix. Worked on a few and biggest issue I have ran into are cold of broken solder joints on the coils. Second most repeating problem is a diode in the power supply. Everything is super easy to get to and you only need Tractor Tools to work on it.
  7. N8FVJ
    The amplifier is known for the HV transformer to fail. If you remove the HV leads to the rectifier and it blows the fuses, you know the transformer is bad. Careful of High Voltage inside. If it does not blow the fuses with the HV transformer wires disconnected, it is likely the capacitor bank shorted or possibly the HV rectifiers. Any of these if you can solder you can service it. If you were down the street from me I would fix it for you.
  8. KD6WKY
    KD6WKY Ham Member QRZ Page
    Anybody know somebody with skills on the west coast that can do a repair on my Ameritron AL-811?
  9. WB2WIK
    What's wrong with it? (In other words, what exactly are the "symptoms"?)
  10. KD6WKY
    Hissing, falls out of tune when plate current is slowly advanced. Very little power amplification. Replaced tubes. Same symptoms.
