ad: AALogic-1
AM BROADCAST TOWER SLIDE SHOW
Discussion in 'Videos, Podcasts, & Blogs' started by AC0GV, Jan 5, 2025.
  1. AC0GV
    AC0GV Ham Member QRZ Page
    Some old pictures from WLBL (am) Auburndale, WI.
  2. WA7ARK
    WA7ARK Ham Member QRZ Page
    What are you going to learn, except how not to build a ham antenna.
  3. AC0GV
    That was used as a ham antenna one night (with permission) and it did not work as well as hoped.
    PS;TNX for moving the post, much better choice.
  4. WA7ARK
    The reason that I made that snide remark is because the goals for building the best antenna to get a signal from the AM BCB transmitter to grandpa's receiver sitting on a kitchen table 25mi distant are not optimum for building an antenna for 40meters, even though a lot of hams believe that...
    K0UO likes this.
  5. N1BCG
    N1BCG Ham Member QRZ Page
    Here are some good Part 73 lessons for Part 97 ops...
    1) The use of ball gaps or a similar configuration is important for discharging static build up on non-grounded antennas. Placed at the base of a tower or closest point to ground of an antenna will give a low impedance path to ground for an induced or direct lightning strike. The addition of a single turn loop in the feedline will make the feedline appear as a higher impedance.
    2) Position tuning inductors in different planes to minimize interaction.
    3) A Port-A-John can make a great enclosure for your 630 meter antenna tuner once the blue water is cleaned out.
    K0UO, W3SLK, AC0GV and 1 other person like this.
  6. W3SLK
    W3SLK Ham Member QRZ Page
    N1BCG said:
    Thanks, Clark! I remember that when I am transmitting wwwwaaaaayyyyyy down there!;)
ad: A2ZTech-1
