ad: M2Ant-1
All the power in the world and not enough battery!
Discussion in 'Amateur Radio News' started by VK6FLAB, Mar 2, 2019.
  1. WA6VVC
    WA6VVC Ham Member QRZ Page
    I was thinking the same thing with the diodes. Add a switch across the diodes when your down to the end and you'er on reserve power time. Seems to me it would provide a little more voltage headroom for some of those sensitive less that 12 volt rigs. NO???
  2. K3KIC
    K3KIC Ham Member QRZ Page
    That's not how you calculate efficiency. You need to calculate the total energy used and deduct the amount lost in the diodes.
  3. WP2ASS
    WP2ASS XML Subscriber QRZ Page
    The rig pulls 22 amps.
    At 1.2 volts drop, that's 24ish watts.
    For a rig that pulls 22 amps at the given 16 volts we are looking at 352 watts of input power from the batteries, give or take.
    My simplistic formula was still pretty damn close, and he's still in the 90s.
    Being pedantic doesn't make you right.
    Even if you wanted rig input power alculate the power used that's 22x13.8= 304 watts. And the 22 watts wasted by the diodes still puts him in the upper 80s this way.
    And you still don't have the problems with a DC to DC cheap chicom switcher.
    If you have a problem with the math, show where it's wrong so people can learn. Please don't just sideswipe with a fairly useless comment.
    --Shane
    KD6VXI
    AG5DB likes this.
  4. K3KIC
    You need to calculate Watt hours or similar units to determine which approach is more efficient as both battery voltage and current draw is dynamic during discharge.
    Your response included the comment that math was easy for some of use and then you proceeded in using the wrong analysis.
    The numbers you provide above are an instantaneous calculation of losses at the start. Not across the full discharge cycle.
    KF5LJW stated that 15% of the total power would be lost using the diode approach. Without running the numbers my educated guess is that he is right. I just would have presented that thought differently. (I've done many battery discharge tests for projects at work.)
  5. WP2ASS
    I us
    I used an apples to apples analysis.
    I was comparing the efficiency of the DC to DC converter vs his diode drop. I also stated that it was being simplified by thinking constant carrier.
    I didn't touch on the dynamic draw, duty cycle, battery VDrop over time, etc.
    His DC to DC converter didn't take any of that into account, either.
    Please don't try to change my intent of the post to fit an argument.
    --Shane
    KD6VXI
  6. K3KIC
    KL5LJW referenced battery capacity. Neither of your calculations related to capacity. I think knowledgeable readers of the thread would have noticed this as did I.
    I merely pointed it out because of your quirky comment.
    As someone who operates remotely I wouldn't throw capacity away when I'm on a mountaintop and worked hard to haul that weight up the hill. So I wouldn't use diodes to drop the voltage.
    I just hook up the battery with the understanding that it's a tad over the voltage spec for a while.
  7. 4Z1UG
    4Z1UG Premium Subscriber QRZ Page
    Could you use one of the Chinese buck converters that keep the output voltage constant as the battery voltage starts above the 13.8 then falls below it?
  8. N7KO
    N7KO Ham Member QRZ Page
    Thank you, Very good information, and well written. You shed some light in that Rabbit Hole.
  9. NN6EE
    NN6EE Premium Subscriber QRZ Page
    I got tired of keeping an eye on the earlier flooded marine batteries (12vdc+) because during warmer spring and summer months you'd have to make sure that the electrolyte in the cells was always TOPPED-OFF!!! So we changed to "AGMs" instead, and those have been serving us VERY WELL FOR 6yrs so far!!!
    PS, We use ours for a very modest "Solar-panel" arrangement!!! It's very gratifying to some times "Thumb your nose" @ the local ULTILITY COMPANY!!! :)
  10. WA4KFZ
    WA4KFZ Ham Member QRZ Page
    The power lost in passive diode configurations can be reduced dramatically by using active diode configurations. A simple control IC operates a power MOSFET switch. The voltage drop across the device is reduced from volts to a few millivolts. Power dissipation drops accordingly.
    https://en.wikipedia.org/wiki/Active_rectification
  11. WA2LXB
    Single Bioenno 20AH LiFePo with up to two (2) Bioenno 28 watt solar panels plus light weight Genasun GV-10-LI-14.2V MPPT charge controller . For the price points I love the combination...no hash from the Bioenno battery electronics or the Genasun. This setup is great for SOTA with the solar panels and for field day, where I plug the wall charger into a generator or wall outlet. The supplied Bioenno wall charger has no problem keeping the battery topped off while running the IC7300 at 100W and field day duty cycles.
    I am considering a much larger fixed station battery bank at some point in the future...I haven't done any research or calculations, but I like the idea of the flooded lead acid Johnson or an AGM deep cycle paired with a battery voltage booster when needed. Basically, golf cart/off grid solar batteries with a well engineered battery maintainer.
    And as Onno implied, there are some good tools (and goodies!) on the 4 State QRP website: http://www.4sqrp.com/resources.php
  12. KY5U
    KY5U Ham Member QRZ Page
    (My apologies if someone else posted about this...)
    For batteries, "graphene" is a game changer too. The first benefit is being demonstrated by Samsung with super fast charging. Imagine a QRP rig battery that could recharge in 5 minutes.... Click on linky below picture to read article....
    Graphene Balls
  13. W4EAE
    W4EAE XML Subscriber QRZ Page
    The problem with new quick charging battery development it that it is all either geared toward smart phones (too small for anything other than QRP use), or toward electric vehicles (too big for Amateur use).
ad: cq2k-1
