Alinco DX-SR8T ans Omni-rigV2 or V1
Discussion in 'Amateur Radio Software' started by VK4GAP, Mar 6, 2020.
  1. VK4GAP
    VK4GAP Ham Member QRZ Page
    Anyone else interested in trying to figuring it out?
    I'm using the Alinco usb thingy .
    1st , yes i have contacted VE3NEA , he replied very quickly , the user/programming language file he seems to point to is just gobbledygook to me and as i aint a software dude so not much help to me , i did let him know btw .
    Anyway after alot (hours) i managed to fluke at least the rig to be "online" in the client , before that it never did anything , so now i cop a rig not responding so that is the next thing at least .
    This is just to read the VFO frequency at first .
    Here is what i ended with up in the dxsr8.ini , i tried all the commands to read the vfo and always came up with nothing .
    [INIT]
    Command=(AL~RR_RXF)
    going to try the AL~RW_RXF AL~RR_RXF together next time .
    The above has made the radio online at least , , so far tried a few others to see if it reads the frequency but no luck as yet , yes i'm changing 1 parameter at a time then test and keep going after that changing stuff (the easy way lol) .
    A example that has not worked so far.
    [INIT]
    Command=(AL~RR_RXF)
    [pmFreqA]
    ; VFO A frequency
    Command=(AL~RR_RXF)
    Value=8|8|vfText|1|0
    ReplyLength=16
    [STATUS1]
    ; READ VFO A
    Command=(AL~RR_RXF)
    Value=8|8|vfText|1|0|pmFreqA
    ReplyLength=16
    The full command list from the interweb i complied up years ago , i glad someone kept it all .
    DX-SR8T commands , RR=READ RW=WRITE ,
    Set frequency AL~RW_RXF14200000
    Read frequency AL~RR_RXF also may be (AL~RR_RXF%08d) or (AL~FW0%010d)
    RF gain status AL~RR_RFG
    RF gain 0dB AL~RW_RFG00
    RF gain -10dB AL~RW_RFG01
    RF gain -20dB AL~RW_RFG02
    RF gain +10dB AL~RW_RFG03
    Mode status AL~RR_RFM
    USB mode AL~RW_RFM00
    LSB mode AL~RW_RFM01
    CWU mode AL~RW_RFM02
    CWL mode AL~RW_RFM03
    AM mode AL~RW_RFM04
    FM mode AL~RW_RFM05
    Power status AL~RR_PWR
    High power AL~RW_PWR00
    Low power AL~RW_PWR01
    Sub low power AL~RW_PWR02
    PTT status AL~RR_PTT
    PTT release AL~RW_PTT00
    PTT press AL~RW_PTT01
    B/width status AL~RR_NAR
    Wide b/width AL~RW_NAR00
    Narr b/width AL~RW_NAR01
    AGC status AL~RR_AGC
    Set fast AGC AL~RW_AGC00
    Set slow AGC AL~RW_AGC01
    N/B status AL~RR_NZB
    N/B off AL~RW_NZB00
    N/B on AL~RW_NZB01
    UT/LT status AL~RR_ULT
    UT/LT fil off AL~RW_ULT00
    UT/LT fil on AL~RW_ULT01
    Split AL~RR_SPL
    Tuner to tune AL~RS_TUN
    Radio model # AL~WHO
    AL~FW0%010d IN KGSDR AFTER READ AL~RW_RXF WHAT IT DO?
    ALSO FOR DXR8 BELOW IN KGSDR ,
    AL~RW_RFM05 < SUPPOSED TO BE FM(ABOVE^) , BUT STARTS IN AM!
    AL~SW_IQM01
    AL~SW_IQF 0000
    AL~SDRON < SDR ON?
    AL~IQ0 < SDR OFF?
    from KGTRX SOFTWARE DX-SR9
    AL~RW_PTT00 ,TX OFF
    AL~RW_PTT01 ,TX ON
    AL~RS_TUN ,TUNE
    AL~RW_RXF ,write freq
    AL~RW_RFG0 ,write rf gain zero?
    AL~RW_RFM ,write mode
    DX-SR8 COMMANDS
    AL~RW_RXF , write freq
    AL~RR_RXF , read freq
    AL~RW_RFM , write mode
    AL~RR_RFM , read mode
    AL~RW_RFG , write rf gain
    AL~RR_RFG , read rf gain
    AL~RW_AGC , write rf gain
    AL~RR_AGC , read agc
    AL~SW_IQM , sdr iq only
    AL~SR_IQM , sdr iq only
    AL~SW_IQF , sdr iq only
    AL~SR_IQF , sdr iq only
    AL~RW_NAR , write narrow bandwidth on/off?
    AL~RR_NAR , read narrow bandwidth on/off?
    AL~SW_RIT , write rit on/off?
    AL~SR_RIT , read rit on/off?
    AL~SW_DIM , write dim on/off?
    AL~SR_DIM , read dim on/off?
    AL~SW_LED , write led on/off? s-meter?
    AL~SR_LED , read led on/off? s-meter? (what led?)
    73 .
  2. VK4GAP
    A non update .
    After plenty of tries to me something else has to be turned on via the commands , the radio is online yet is not responding it says with the client.
    So going to poke about in this to see what is going on https://freeusbanalyzer.com/ and try to figure it out , also downloaded this KGTRX for the DXSR9 and take a peek again in the .exe .
