AL-572 check out forward needle
Discussion in 'Amateur Radio Amplifiers' started by W8NIC, Nov 10, 2019.
  1. W8NIC
    W8NIC Ham Member QRZ Page
    Doesn’t matter how much drive and output, the needle goes nuts when transmitting on cw mode. The forward (kw) needle slams to the right. Anyone know why?
    Thanks!
  2. N8FVJ
    N8FVJ Ham Member QRZ Page
    Amp could be oscillating. Try tuning with more capacitance on the load capacitor. More capacitance would mean about 50 watts less output for starters.
  3. WB2WIK
    The meter indications posted indicate a terrible SWR.
    The FWD power is an indication for FWD + REF, always, so it can read >>1kW when the output power is <<1kW, if REFlected power is high enough.
    Try it with a good kW-rated 50 Ohm dummy load and see if it reads more normally.
    WA7PRC likes this.
  4. W8NIC
    so I tried it on a g5rv jr and a hustler 6btv, both hooked up to a palstar AT4K, swr at 1.1 to 1 and still the needle slams the wall. hooked up to a palstar 50 ohms dummy load, same results. Good output at 1kw with 60w drive. With amp on stand-by, radio at any wattage, needle does the same thing, pointed straight up on dead key.
    Could it be a bad meter?
    Sorry for the stupid questions guys, I don't know much about amps.
    Please help.
    Thanks.
  5. KA9JLM
    How old is the amp ?
    Did you do the normal MFJ QC checks before power up ? (Loose screws, Extra screws, Solder connection inspections...)
    Good Luck.
    KD2ACO likes this.
  6. W8NIC
    Don’t know, I just got it not to long ago .
  7. KD2ACO
    Did it ever work correctly?
    Sounds like IC301 on the meter board may be toast.
    Is the meter pinned all the time when the amp is on?
    click for bigger pic
  8. W8NIC
    meter is pinned only when transmitting, it's a zero when unkeyed.
  9. WB2WIK
    No, it wouldn't be the meter itself -- that's very unlikely.
    That meter is driven by an active circuit which makes it a "PEP" meter and there's a problem on that board.
  10. W1QJ
    W1QJ Ham Member QRZ Page
    There is an adjustment for that meter. It could be mal adjusted.
