Adhesive for tacking coax to concrete
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by N5YPJ, Aug 2, 2020 at 1:10 AM.
  1. N5YPJ
    N5YPJ QRZ Moderator QRZ Page
    Hi
    A change of plans where I intended to route a coax from the noise antenna to the noise canceler unit puts it too close to cable TV internet both running both parallel and crossing it. The back porch the coax to be installed will run across has a cement floor with a 6 inch high cement ledge. I would like to run the cable along the ledge where it meets the floor "tacking" it every few feet with an adhesive just to hold it in place and well out the way of foot traffic. I really don't want to drill and install cement anchors for this project. Has anyone used an adhesive they can recommend? I'm concerned about possibility of an adhesive damaging the coax jacket.
    Thanks for reading. Have a great day.
    Richard / N%YPJ
  2. AJ5J
    AJ5J Ham Member QRZ Page
    I would test a short length before the full glue-down but I suspect two-part epoxy would be dandy.
    Jeff
    N9LCD likes this.
  3. N7EKU
    N7EKU Ham Member QRZ Page
    Hi,
    I'd use some silicone sealant. It would last as long as you need it and still be easy to take out later. Would be safe for a p!astic coax jacket -- usually PVC I think.
  4. KL7AJ
    KL7AJ XML Subscriber QRZ Page
    try FlesSeal, as advertised on late nite TV.....again and again and again.
  5. K0UO
    I have stuck coax up for a number of years with liquid nails adhesive
    AJ5J likes this.
  6. AJ5J
    Hot glue often works surprisingly well and is removable, too. I prep large or long surfaces with a heat gun before applying.
    WR2E likes this.
  7. N2IPH
    N2IPH Premium Subscriber QRZ Page
    Adhesive silicone sealant will work. This is stronger than plain silicone caulk, they are not the same. Either would probably work.
    It can be removed, but will require using a stiff wire brush. You can not easily get it out of the concrete, you will end up removing the surface of the concrete where the sealant was, so the texture and color of the concrete will change too in those areas.
  8. KU3X
    KU3X Ham Member QRZ Page
    Try Gorilla Glue. That stuff really works.
    Barry
  9. WR2E
    WR2E Ham Member QRZ Page
    I vote for hot glue. Easier to remove when the time comes.
    KU3X likes this.
  10. N9LCD
    N9LCD Ham Member QRZ Page
    I'd put your chosen adhesive directly on a short piece of coax and wait several days for the adhesive to fully cure and set. Then see if the ahhesive had any effect of the jacket.
