Adding EPROM messages to the Accu-Keyer Extended project
Discussion in 'Homebrew and Kit Projects' started by W0RIO, Apr 1, 2021.
  1. K9LY
    K9LY Ham Member QRZ Page
    Nice work, W0RIO. My local ham club built the Accu-Keyer as a club project in the 70s. It was fun to gather at a member's home to stuff and solder the boards. I used mine for many years. Even added the Accu-Memory board (using 2102 memory chips) a few years later, re-packaging it with a regulated power supply into a wood-grained TenTec enclosure (one of many home projects for this budding engineering student). Eventually it was replaced by a MFJ keyer with non-volatile memory, but I still have that Accu-Keyer tucked away.
  2. W0RIO
    W0RIO Ham Member QRZ Page
    I built my original accu-keyer in the late 70s then I built the accu-memory board with the outboard LED display. I managed to squeeze
    it all into a 6x6x4 aluminum box that I built in Jr. High school metal shop. At some point, I managed to short the input and
    output pins of the LM309K 5V regulator and fried many of the soldered-in ICs on both boards. Oops ;-) talk about a free education
    experience.
    I loved the keyer so much that I removed all of the chips from the accu-keyer board and installed those horrible "molex pin"
    sockets, and got just the keyer part functioning again. I never fixed the accu-memory board.
    Many years later, I removed the molex pins and replaced them with good sockets.
    The board had non-plated holes so it required a lot of repair work to fix the numerous lifted traces.
    I swapped in LS TTL chips and used the accu-keyer for many years.
    Just for fun, I recently re-built the LED display board from the accu-memory and stuck some 74LS247 chips in place of the
    burned out 7447 display drivers, then I re-wired the board to have leading zero blanking. The LS247 chips add the top segment to
    the '6' and the bottom segment to the '9' for better looking digits. The 7 segment displays also had to
    be replaced since they were fried in the earlier power supply apocalypse. I now have a handy 3 digit TTL counter.
    For fun, I connected the counter's clock input to the output of my new accu-keyer extended project and noticed that it sensed
    an extra pulse when the keyer was sending dashes. That was cured by adding yet another R-C delay to the keyer output signal.
    The original accu-keyer actually has quite a few little glitches that need extra R-C delays to fix. It *was* designed in
    the early days of TTL, so that's not too surprising.
    This is a homebrew project that I've been working on for nearly 45 years, it was overdue for a complete new build,
    hence the accu-keyer extended project. Did I mention that I LIKE playing with TTL chips?
    In around 1990, I used a Motorola 68HC11 EVB (evaluation board) to make an interrupt-driven iambic keyer using 6811 assembly
    language. That project worked quite well, but the board was re-purposed for another project. I may try to revive that project.
    K9LY likes this.
