A boat anchor that won't sink
Discussion in '"Boat Anchor" & Classic Equipment' started by AA4OO, Jan 27, 2021.
  1. AA4OO
    AA4OO XML Subscriber QRZ Page
    The AN/GRC-9 Floats
    I recently acquired this piece of military communication history. One interesting feature, is that with the front cover attached, it is waterproof and buoyant. A 38 lb boat anchor, that won't sink.
    The following is a partial re-post from my blog post. QRZ has a limit of 20 images so there are far more images on the blog. A link to the video is at the bottom of the post.
    My lovely (and radioactive) RT/77-GRC/9
    I don't recall where I first read about the Angry Nine, but it captured my imagination. I read everything I could find about them and decided it would be great fun to operate such an antique on the ham bands. There is no logical reason to desire such a QRP radio. The low power output on CW is indeed, 5 watts and high power is a pileup busting 15 watts. The AM transmission are 1 watt and 7 watts respectively. That's almost QRPp for AM mode.
    I'd had some experience restoring old tube equipment; my Heathkit HW-101, Knightkits VFO and Hallicrafters keyer, and I figured I'd take the next plunge and learn to use a receiver-transmitter combination and see how mobile high-voltage power worked from Vibrators and Dynamotors.
    These radios seemed to have been more plentiful in the surplus market 10 - 20 years ago. Now you'll occasionally see one come up on eBay or other sites, but often times they are in very rough shape or the they are foreign language versions. I bid on a few auctions over the past couple of years and the bidding always exceeded my threshold for what I thought it was worth. The one above was part of an auction from an individual who had actually trained on these units prior to deploying to Vietnam. Later in life he became interested in finding one and spent time in military surplus warehouses going through pallets of equipment to find one in good shape. This particular unit is made up of a Lewyt manufactured transmitter and a Telefunken receiver. The original owner preferred the receiver characteristics of the Telefunken over the Lewyt manufactured model, so he paired the two.
    Many of these old units are radioactive, due to the radium paint used on the front panels to make the lettering glow in the dark. This particular unit is off the lower scale on the Geiger counter and must be handled with care. Basically, I have to be careful to not touch my face with my hands after operating the unit and wash my hands thoroughly. Radium emits Alpha particles, which are not especially strong but the resultant radioactive dust from the front panel shouldn't be breathed or ingested. I plan to paint a clear-coat over the remaining lettering to lessen the Alpha particle emissions.
    Hot receiver, in more ways than one
    The AN/GRC-9 is a set of components primarily comprised of the RT-77/GRC-9 receiver-transmitter, capable of operating between 2-12 MHz in CW, MCW and AM modes. MCW is a modulated form of CW that can be received by radios that do not have a BFO (i.e. a normal AM receiver).
    It is a mid to late 1940's design and was first documented field use in the Korean War, and was in active use through the Vietnam War and continued to be maintained in US military warehouses until 1974. It was in use by other nations long after, most notably the Dutch military.
    Out of the case, tracing a low B+ power problem
    Close up of the bottom of the receiver board
    Transmitter
    Power on the move
    Designed to be used in the field, both vehicle mounted and carried by mobile infantry; there were a number of ways to supply power to the unit. There were a few different Vibrator/Dynamotor units, that could operate from common DC voltages of the time (6v, 12v, 24v) as well as a hand cranked, field portable generator.
    Keep in mind that the state of the art at the time of its design used vacuum tube technology and in the case of the RT/77-GRC/9 it required the following voltages:
    • Transmitter Plates -- 475 - 580 v @ 100ma
    • Transmitter Filaments -- 6.5 - 6.6 v@ 2 amps
    • Receiver Plates -- 105 - 120 v @ 45ma
    • Receiver Filaments -- 1.35 - 1.5 v @ 500ma
    • Keying Relay -- 6.0 - 6.9 v @ 575ma
    That's a tall order for mobile and portable power supplies but designers in the 1940's were quite clever in packing power supply units. I managed to obtain both the hand cranked GN-58 generator with the base chassis and seat for portable operations, and a DY-88 for fixed / mobile operations.
    DY-88 mobile power supply
    DY-88 set to 12v powered by Amateur 12v supply
    Vibrator power supply for low B+
    Power filtering
    I supply the DY-88 from either an RV battery or an amateur 12v power supply. When in Standby the DY-88 draws less than 1 amp, but placing the radio in Send mode switches on the Dynamotor which draws 12 amps @12v, without key-down and up to 14 amps on high-output key-down. It will drain an RV battery pretty quickly at that rate if the radio is left in Send mode, and works an amateur power supply pretty hard as well. So don't expect to operate remote off a battery alone for too long if your having lengthy QSOs. An added benefit of the DY-88 is that when the enclosed Dynamotor is running you'll have a nice extra 85 dB of generator noise to accompany your listening pleasure.
    GN-58 portable field hand-cranked power supply
    Generator head in carry bag
    NOS Shiny
    The GN-58 is a tough workout since it has to be cranked by hand at 60 rpm continuously. Obviously, you need a partner unless you can figure out how to crank it with your feet while sending CW. You will also want that partner to help you carry the GN-58, and the accompanying accessory bag for the chassis and seat. IT'S HEAVY. I haven't weighed everything, but according to the manual that came with the set, the radio / generator / accessories including antennas comes out around 120 lbs.
    If you have a BC-48 battery hooked up then your human power supply can pause cranking while your receiving. I have a BC-48 battery enclosure that has been gutted of the original, long-dead material and replaced with 10x 9v batteries in series for the low B+ and two D-Cell batteries in parallel for the receiver filament supply.
    Accessories
    Bag of goodies
    The radio itself has a carry bag, as well as a bag for the GN-58 legs and seat, the vertical antenna, and miscellaneous.
    There's another bag (shown above) for carrying power supply cables, keys, hand mic, long wire and doublet antennas, external speaker, torture device headphones, torture device in-ear phones, as well as a box of spare tubes for the radio.
    If you're traveling in a squad sized group, then many hands make light work, otherwise you're going to be making a lot of trips hauling your QRP rig up the hill.
    Headphones
    These Western Electric headphones clamp tightly over your ears sealing out QRM and squeezing your head like a vice. After 10 minutes I was confessing to sins I'd never committed.
    In order to use the headphones the RT/77 receiver must be removed from the case and an impedance switch on the back, changed from 4000 to 250 using a screwdriver. The ham I bought my set from had constructed a CW audio filter along with an impedance switch on an outboard box, that allowed the use of the headphones without switching the impedance on the receiver unit.
    Homebuilt CW filter with impedance switch
    Speaker
    The external speaker is a rugged, high impedance device (4k Ohms), that after all these years can still output audio at high volumes without distortion. It has a built in thumbscrew clamp that allows it to be attached to vertical or horizontal objects.
    Alternately, the thumbscrew can be used in combination with the vice-like headphones to extract information from a prisoner.
    Antennas
    The AN/GRC-9 comes with 3 antenna systems; a multiple section, whip vertical for quick field setup and mobile use, a long wire that can be quickly deployed in a fixed station as a sloper, and a doublet for best reception, transmission in a fixed location.
    For testing purposes I have my radio hooked up to my 80m Windom, which it tunes very nicely on 80m, 60m, 40m and 10m bands.
    When the weather warms a bit I will be taking the radio out for some portable use and I'll try it out with the antennas that are part of the AN/GRC-9 set.
    Spares
    As a military radio, it was expected that repairs should be performed in the field when possible. The radio shipped with spare tubes for the receiver-transmitter, as well as spare tubes and vibrators for the DY-88 power supply.
    More to come
    In the few days I've had the AN/GRC-9 the only problems I've encountered have been related to the old DY-88 power supply. Old vibrators cans are generally seized up, as was the case with mine. Eventually mine became un-stuck after repeated applications of power but there are some methods to restore truly frozen ones using AC current and light bulbs (see Notes section below).
    I've made about half a dozen contacts on the ham bands, including a 40m contact to a station in TX which is kinda DX for my locale. I've received nice signal reports. I've specifically asked stations about my "chirp" during QSOs and they've reported it as "not bad" and "charming". When operating from the VFO (master oscillator) rather than a crystal, the GRC-9 will "chirp". It was considered an acceptable design trade-off at the time. I've listened to the transmitter from a remote WebSDR station to hear the chirp for myself, and I agree that it isn't extreme and lends some character to the station. The unit does drift about 200 Hz during a QSO which I also think is quite acceptable for it's age. It's possible that if I spent more time in Send mode prior to a QSO to allow the transmitter tubes to warm up the drift might be lessened, but keeping the radio in Send mode puts quite a load on the power supply (both the 12v supplying the DY-88 and the human cranking the GN-58).
    The RT-77 Telefunken receiver doesn't offer much in terms of selectivity and on a crowded band there's a lot of stations to contend with in the passband. The outboard CW filter deals with this nicely, but it is so narrow that when shifting from Send to Standby, the resulting frequency shift often throws the station I'm receiving out of the filter's passband, so that's a bit tricky.
    The receiver's tuning knob also is very coarse, in that fine adjustments are made by breathing on the knob. However it has zero backlash, which is amazing in a piece of equipment this old. The markings on the receiver are in 50 kHz intervals so the only way to really figure out where you are is to look at RBN for your spot.
    50 kHz spacing when reading the frequency on the receiver
    Note the 7.2 is 7.200 MHz in the 40m band
    Video summary available
    Rich, AA4OO
    DK7OB, KD2ACO, W1BR and 8 others like this.
  2. W1BR
    Nice score. Those are very clean pristine examples. Most of the ones I run across have lost whatever war they
    served in... thanks for sharing.
    AB9LZ likes this.
  3. AA4OO
    Thanks. Those Western Electric headphones sound fantastic with CW and work really better with my Eagle than the other headphones I've been using, but man they are a torture to wear. I've ordered some foam ear pads but I don't think that will help that much. The spring steel in the head band is pretty resilient to return to it's original shape no matter how far I bend it . They don't make 'em like they used to.
  4. N4CVX
    N4CVX Premium Subscriber QRZ Page
    Thank you for this great presentation! It brought back old memories, some good and some not so good, especially being a Private First Class and having to crank the generator while the Specialist Four sent messages and the Sergeant watched us work. Well, OK, when I finally became that Sergeant, I watched my "boys" work too. By the time I was a Chief Warrant Officer, I found that I was the only one in our detachment who knew Morse and could reliably train "our local national counterpart soldiers" to run this rig in the field. First time I set one up was at REFORGER 1963 in the German forest, in the snow, with a Chief Warrant Officer watching me, the Sergeant, the Specialists and smoking a big cigar. By the time I retired in 1988, everything we had was solid state and "modern". Ah Memory Lane. 73's OM es tnx fer ur posting, de N4CVX, ex-DA1BB, ex-VP2EHF, ex-KR6DEM.
    PU2OZT and W7UUU like this.
  5. KL7AJ
    KL7AJ Ham Member QRZ Page
    I think the Gibson Girl was s'posta float too.
  6. AA4OO
    Thank you for sharing that view into the past, and thank you for your service.
    N4CVX likes this.
  7. AA4OO
    In the spirit of going with a modern vibe
    When I received first powered up my DY-88 that powers the GRC-9 the vibrator power supply refused to start but eventually, after a bit of percussive maintenance (banging) and reapplying power it started. Over the past few weeks it usually will start, but there are still occasions where power has to be switched off and on repeatedly to get it to start. It is obviously entering failure mode.
    There is a procedure using an AC light bulb in series with the contacts to attempt to freshen a stubborn one up, but the procedure is hard on the contacts and generally only restores it for a while. It needs to be replaced, and vibrator power supplies have not been manufactured for many decades. The NOS vibrators are generally not good due to the breakdown of the materials inside over the decades rendering them bad even if they've never been used.
    The solution is to replace the mechanical operation of the vibrator power supply with a solid state equivalent.
    Entering the age of the Jetsons, we have these nifty things called transistors that are excellent and making and breaking contact of DC voltages rapidly and reliably. I found a number of articles describing a solid state circuit I could build but most did not offer much in the way of circuit protection if a component upstream failed, or if the circuit itself failed. There are a lot of difficult or un-obtainable components in that DY-88 that I'd rather not have to replace due to the failure of the Vibrator Power Supply.
    I read an article by a GRC-9 enthusiast from 2004 (NC6AV) on using a commercial circuit that was designed for this very purpose to replace mechanical vibrators in vintage automobile radios https://www.radionerds.com/images/c/cd/Wire_VBN-1.pdf. In the article describes the procedure for using a solid state replacement.
    I purchased my solid state module from http://dodgem37.com/vibrator-conversion-module/ and ordered some high voltage diodes from antique radio supply to use in the conversion. I cut apart a non-functional vibrator module to use the phenolic 7-pin base for the VBN-1 module.
    Note
    The instructions for soldering the VBN-1 module are great with one exception. From the instructions:
    . . . The pins are numbered 1 to 7, pin 1 is the large diameter pin on the right, and pins are counted clockwise from that pin. . . .
    If you are looking at the base of the vibrator there are 2 large diameter pins. The instructions say count them from the pin on the right. That pin will be different if the large diameter pins are at the bottom rather than the top, when looking at the base. Turn the base such that the two large diameter pins are facing you and located at the top (12 o'clock position). Now the instructions will be correct. This may seem minor, but when I first read the instructions I was looking at the two large diameter pins situated in the 6 o'clock position and all the pins were off-by one.
    Results
    The replacement circuit works a treat, except that I can't hear the faint humming from the DY-88 now when the radio is in Receive mode. Of course that is immediately obliterated as I turn the radio to SEND and the Dynamotor leaps to noisy life.
    Next step would be to JB-weld the can back to the base to restore the look, but I'm debating whether to do that. I kinda like the look of the modern mixed with vintage vibe (vibe, get it?).
    I also was able to find a FT-243 type crystal oscillator suitable for use in the CW portion of 40m with the transmitter. The transmitter uses a frequency doubler so any crystal needs to be half the value I wish to transmit on. I found one at 3523 Hz and it is spot on 7046 when transmitting. The first QSO with it was a great success. The other station reported no drift and no-chirp in my tone. Trying to find some suitable for use on 80m CW now. They would need to be in the AM broadcast band like 1750 kHz to work when doubled. I'm also considering one for 30m as the chirp is worse as the frequency goes up when using the Master Oscillator built in rather than a crystal. I have 6 places for crystals (2 for each of the GRC-9 bands). I'll probably try my hand at sanding/etching crystals to get them where I want but I need to build a way to test them using my oscilloscope rather than taking the transmitter out of the case each time I need to test them.
    I'm still exploring my boat-anchor that floats. I was able to find the carry bag for it, so now I have bags to carry all the components for portable field use with the GN-58 hand crank generator. I just have to find the poor slobs to help me schlep it into the field and someone to crank the generator. I have used the shell and connector of a BA-48 battery to hold 10x 9v batteries in series for the low B+ and 2 D-cells in parallel for the filament and that worked well, so whoever is cranking the GN-58 only needs to do so when I transmit.
    AH7I and KP4SX like this.
