706 wont turn on
Discussion in 'On the Road' started by W1LRC, Dec 29, 2013.
  1. W1LRC
    W1LRC Ham Member QRZ Page
    have a 7 year old 706 running mobile for 7 years. All of the sudden it started turning off and then on right away. It now wont go on at all. I brought it to the bench and have the head mounted on the unit and powered direct from a battery. I have beat on it, looking for an intermittent...no luck. The power button clicks...and I am going to dig into the control head to check it today. All All fuses look ok. Can any one suggest a direction to go. Thanx, Dave W1LRC
  2. K0BG
    K0BG Ham Member QRZ Page
    You posted this in tow forums. All of the answers are in the Mobile forum—where they should be!
  3. N0MSU
    N0MSU Ham Member QRZ Page
    Check the inside fuse.Just did mine this morning and found it had blown.
  4. K4BOI
    K4BOI Ham Member QRZ Page
    Put a voltmeter from the + terminal on the battery to the + terminal on the 706 side of fuse. Push the on button, any deflection of the meter would indicate bad connection, bad fuse, or bad power cable. Do the same on the - terminal of the battery to the most - point on the 706.
    Good luck,
    Lewis
ad: TIDrad-1
