4m 50w amp finals change?
Discussion in 'Amateur Radio Amplifiers' started by OG6Z, Apr 30, 2021.
  1. OG6Z
    OG6Z Ham Member QRZ Page
    Hi om's im attented buy a 50w 4m 70mhz amp .
    The amplifier uses BLW60 transistor which due to datasheets is rated to max 100w.
    Is It possible to replace the BLW60 with MRF150 ?
    And if it is how much More pwr would i get . ? Or do i get any4hing?
    I use 13.8v powersupply . And yes i know that MRF 150 is a 50v final.
  2. G3YRO
    G3YRO Ham Member QRZ Page
    Seems like you have double-posted . . . but in case you missed my previous reply:
    Just because you use a Transistor with a bigger MAXIMUM power rating doesn't mean you will get more power output.
    You would need more Gain (which the device MAY have) . . . and you may also need to alter the output circuit to get more power.
    Roger G3YRO
ad: Preppcomm-1
