40m Vertical Taper Schedule/Design
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by NN1C, Mar 22, 2016.
  1. NN1C
    NN1C XML Subscriber QRZ Page
    Hi Everyone!
    I've been thinking about it for a while - but I think I'm going to build a 40m foursquare. I'd like to make the verticals myself - as I don't have a lot of cash. At the same time - do it right, not twice as I live in New England! I know what happens when things are built to be "temporary"! Does anyone have plans or a design for a free standing (unguyed) 40m 1/4 wave vertical? They will be mounted about 8~ feet up on 4X4 posts in concrete. I'd like to make them all identical, and do so fairly cheaply.
    Thanks,
    Marty
  2. AJ5J
    AJ5J Ham Member QRZ Page
    Would telescoping sections of DXE 6061 tubing suffice? Another thought is fiberglass poles with 14 ga. wire inside, but might not hold up to severe weather like you have up there. Either wouldn't be terribly expensive, at least.
  3. NN1C
    Yes, I don't think fiberglass will play well around here. Does DXE sell them in kits?
  4. AJ5J
    3' or 6' lengths slotted on one end for hose clamps.
  5. NN1C
    Do you think I should taper at all? I think WB2WIK had mentioned it before.
  6. WW1WW
    WW1WW Ham Member QRZ Page
    Take a look at Maxgain systems. They have pushup masts that might do the job at a reasonable price.
  7. NN1C
    Aren't they fiberglass? I'll look, as you know NE weather, but that sounds risky.
  8. AJ5J
    Not sure but I think they sell both---fiberglass would work with a wire running up them in any case. (you could use more than one wire a la cage vertical for more bandwidth, too).
