I have two t200 2 powered iron toroid cores. Can I make a 4:1 current balun with them? To be used on a OCF Dipole.
Thanks for the info. I will be operating at 30 Mhz or more. Looks like I will order the Ferrite cores before making the balun.
Must use ferrite. Powered iron has very little choking reactance. Either use two each FT 240-43 cores or two each FT 240-31 cores. Mouser is a good place to purchase ferrite or use this guy. http://kitsandparts.com/toroids.php You can use a 4 x 4 x 2 nema enclosure to put the cores in. Home Depot or Lowe's carries them. Luck on your project. Barry, KU3X
