3Y0K, Bouvet 2026
Discussion in 'Contests, DXpeditions, QSO Parties' started by EA1CS, Jun 17, 2024.
ad: FreeHamClock-2
  1. KR2D
    KR2D XML Subscriber QRZ Page
    Don't use F/H mode on your end. Just stay on your TX frequency. It is far more reliable. Doesn't matter if the DX is running in F/H mode, the contact will work out regardless. The net effect is the same as MSHV.
    SuperFox mode is better in my opinion than either F/H or MSHV. Wish more DXpeditions would use it.
    KA2FIR, W2FV, M0AGP and 2 others like this.
  2. W4WN
    W4WN Ham Member QRZ Page
    Cool, Thanks, I didn't know that!
    KR2D likes this.
  3. VA3VF
    VA3VF Ham Member QRZ Page
    My understanding is that if the DX is set to FOX, as in WSJT-X F&H, he is going to call you up to 3 times maximum. If you don't move to a frequency below 1000 Hz, and you won't since you are not using WSJT-X F&H set to HOUND, his attemp to complete the QSO with you is dropped.
    If the call goes through, without you moving down, I don't think the DX is using true WSJT-X F&H.
    Best to see how others are getting through. That will be the clue if one should use F&H or just stay on one's frequency.
    NQ1B likes this.
  4. KR2D
    I never use F/H mode on my end. I have had no problem working any DX that claims to be running as a Fox. It just works. QSOs have not been dropped despite the fact that I don't change TX frequency.
    KA2FIR, NQ1B and N5PG like this.
  5. VA3VF
    Good to know. My experience has been the same as yours with most activations, but not all.
    Either WSJT-X changed - and that is possible since I stopped following WSJT-X developments a long time ago - or the DX is not using WSJT-X, MSHV perhaps.
    KR2D likes this.
  6. WB8VLC
    WB8VLC Ham Member QRZ Page
    I do this but Tuning around trying to find any dx on the hf bands these days is not easy, especially from up here in the Pacific Northwest.
    When beaming towards Bouvet for us up here we point towards the entire southeast US and in this direction the ssb portions of all HF bands are full of POTA callers creating endless QRM and the CW ends are full of people calling on top the DX entirely clueless that a dx pedition is active.
    Knowing ahead of time that a dx station is transmitting on a particular frequency lets me set up my old non spectrum display radio on their tx frequency with my external noise reduction box enabled, this is a lot easier than tuning around blind for the dx station.
    It doesn't matter to me either way because they are blocked to the pacific northwest anyway.
    KA2FIR and KR3DX like this.
  7. WA1GXC
    WA1GXC Ham Member QRZ Page
    I wish you success in getting a 2-way contact with them OM.
    You can do it, and I'll pass on two just possibly-useful pieces of practical advice for all DXing
    If conditions are really poor--extremely weak signals from poor propagation path--just walk away from it
    and come back in a couple hours or try it next day. There's no more frustrating enterprise than banging
    your head against the wall with no real possibly of success. Don't expend your efforts to have them end
    in aggravation. You will have another and better opportunity in the days to follow.
    Same goes for battling against DXing-Dimwits-On-the-Air--especially the new Amateur niche-operating
    activity of DXing on Morse without the benefit of knowing anything about operating on Morse--
    decoder-screens/macros and no awareness of what a typical exchange protocol consists of in completing a
    valid 2-way contact.
    If your operating period just randomly has attracted a bunch of hopefuls who are hopeless--just walk away.
    Eventually they will give up, burn up their linears, or take up producing YouTube videos on DXing and "CW".
    Most important--I just looked up your location and pulled up a Great Circle bearing chart for the Pacific Northwest.
    Bouvet/3Y0 is roughly 090 antenna heading via short-path. Experienced operators will tell you that, counterintuitively,
    the optimum propagation facilitating a contact is quite often via Long-Path--
    Phase or rotate your directional antenna to head roughly 270 deg True---West. It's often worth 6 or 10dB in my experience,
    especially to stations in Oceana and Austral/ sub-Antarctic areas; and it somewhat inhibits the USA interference you've noted.
    Stay with it, and don't let yourself be worn down.
    Good luck.
    The map projection is "Azimuthal Equidistant" and NS6T has generously created a free
    application for all hams to use. Easiest execution is to populate the "location" box only,
    with your Maidenhead grid-square locator to low-precision--example : "CN84"
    https://ns6t.net/azimuth/azimuth.html
    KE0GXN, M0AGP and AE1P like this.
  8. WA1GXC
    I'm firmly "stuck in the past" as you characterize it, because the past required individuals to develop and work at a host of basic skills. Those
    skills are still valued and developed by newcomers to ham radio who want to grow, develop, and excel--for the pleasure of it and
    for the fulfillment of being good at something they've done all by themself. ( @K6GP )
    You are free to operate in any manner you choose. No one cares. I say again--No one cares. Knock yourself out. If you think
    you've changed with the times, I'm happy for you. But your prior comment informs us you now find yourself in a situation of learned
    helplessness.
    Your choice. Own it.
    K6GP likes this.
  10. KE0GXN
    KE0GXN XML Subscriber QRZ Page
    Anything 5-10 up from 21.295 is a total zoo right now.
  11. KC2QVD
    KC2QVD Ham Member QRZ Page
    Just curious. I was trying to work them before and had 0 luck (which is to be expected on the first day). But when they say "listening up" and I go look at some of the spotting sites, some people say "Thanks 5 up!!!" which makes sense, but then some are 8 up, 10 up, 15 up. How does that work? Do you just pick a spot up from them and hope they're listening to that frequency at that moment? Or should I just do what everyone is doing and go 5 up and hope for the best?
  12. NM9K
    NM9K Ham Member QRZ Page
    Listen back and forth and see if you can discern a pattern of who he's calling back. It'll help you get through. Working DX is a game sometimes.
    KE0GXN likes this.
  13. KE0GXN
    That or sometimes the DX will state "5 to 10 up", etc. when they QRZ.
    It varies...
    However, you can't wrong with what @NM9K advised, always good to listen for awhile first if you can and see what patterns the DX is using.
  14. VA2GK
    VA2GK Ham Member QRZ Page
    I have two ways to approach this.
    First eventuality, I know my signal to the DX station is very weak and a lot are stronger than me, i.e: I'm calling J51A and Europe is all over the place. In that case I find a spot and call there repeatedly without moving, eventually I'll get picked up.
    Second eventuality, I know my signal can compete with the big guns _AND_ I hear most of the pile-up properly. in that case I tune rapidly across the band looking for the station that just got worked (look for a "59 thank you") and transmit on that frequency for the next turn.
    Note that this works in SSB as well as CW, with some minor differences.
    In any case, DX is almost a sport, it's a hunt. And it's rewarding.
    But the FIRST rule is, call only if you can hear the DX.
    And also, if you still haven't, read and heed this: https://dx-code.com/
    AE8EM and KR3DX like this.
  15. K6GP
    K6GP XML Subscriber QRZ Page
    I’m sorry for your frustrations, OM. But I completely understand them and relate to them. This is exactly why a minority of us have an issue with these types of DXpeditions. It brings out the worst of the worst in the hobby. You are not alone in being frustrated by the overall ham community behavior.
    Harry touched on it, I’ve touched on it, many have touched on it. The stress and poor behavior is simply not worth fighting over. This is supposed to be a pastime, a hobby that gives us joy and relaxation in the world.
    That is one of many reasons I don’t use spotters. It adds too much stress. It’s way easier for me to just spin the dial and work who I can work and hear clearly on my own and that’s much more enjoyable, and surprisingly (or not surprisingly) I have better luck finding and completing a contact with a rare station before it’s spotted on the networks.
    I do wish you and the 3Y0K team the best of luck along with anyone else that wants to work them. I’m not a hater. But like you and others have said. Sometimes the risk vs rewards, cost vs rewards and stress vs rewards isn’t worth it. That’s for each of us to decide on our own and those trade offs might not match others. And that’s okay.
    But if you need a break and say “This isn’t fun”. I get you. A lot of people do. Keep your head up my man.
    YO3GFH, WA1GXC and NM9K like this.
