30 to 1 RX
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KB2WVO, Aug 13, 2018.
  1. KB2WVO
    KB2WVO Ham Member QRZ Page
    hello
    tryin to build a 30 to 1 balun RX. 50 ohm in 1500 ohm out.
    thoughts ideas . parts on hand. no it doesnt have to handle power.
    its RX only.
    t-200
    4 inch by 1/4inch core out of a RX'er..
  2. W4OP
    W4OP Ham Member QRZ Page
    If this is for wideband HF, I doubt you will get enough winding inductance with a powdered iron core. Ferrite would be preferred. In addition, an effective current balun is going to require 2 cores. One for the Z transformation and the 2nd for common mode reduction.
  3. WB2WIK
    Unless you do something very special, such baluns usually only go in ratios that are the square of the turns ratio, so it would usually be 25:1 or 36:1.
    For "receiving only," you could use a smaller core and very small gauge wire. The number of turns required (as well as the core material) is based on the frequency range you're trying to cover.
    What frequency range is it?
  4. KB2WVO
    RF.... lol
    i can try few diff freq's
    but looking around 50mhz. can even be in any part of the hf spec. if i need to build a few to get little better RX. then i can do that maybe lol
    the 2 circled. is 50 ohm to 1500 ohm.
  5. KB2WVO
    if i did math right. 1500/50 sq is around 7 wraps to 1. might get me in ballpark on a ferrite rod. problem is the rod is 4 by 1/4" out of a old rad shaft rx.
  6. WB2WIK
    Just noticed you wrote "rod."
    Try it and see what happens. I always use toroid forms for this stuff.
  7. SV1IYF
    SV1IYF Ham Member QRZ Page
    WB2WIC wrote: "...so it would usually be 25:1 or 36:1."
    One can also in-between by 11 to 2 turns = 5.5:1 ratio =>~30:1 impedance ratio.
    73 Nikos SV1IYF
    KB2WVO likes this.
  8. KB2WVO
    so i wasnt to far off with my math. i got 7.5 ...what i will do is start with say 10. work down form there.. easyer to remove then add lol ..
  9. KF5LJW
    KF5LJW Ham Member QRZ Page
    Couple of things I have learned. Just built a RX only antenna for myself lately.
    1. Don't get hung up on trying to figure out antenna impedance, or exact ratios. That is a loosing game. Ball park number hits a home run on RX only.
    2. 75 Ohms' is a better impedance for RX only, easier to work with, and makes tip 1 even easier.
    3. Design for the lowest operating frequency, the rest works itself out. Determines how many primary windings are required. You will know you got it right if the primary turns required is 4 or less with 1 turn being perfect.
  10. WB2WIK
    I'm confused by two posts here:
    First:
    its RX only.
    t-200
    T-200 is a toroid core description. T for toroid, 200 for diameter (.200").
    Then:
    That describes a ferrite "rod," which is not a toroid.
    Which is it, actually?
    The winding would be different for each.
ad: CrossCountry-1
