2014 Ford Explorer
Discussion in 'On the Road' started by WD8RIT, Nov 19, 2014.
  1. WD8RIT
    WD8RIT Ham Member QRZ Page
    Anyone with a Ford Explorer find a way to run a power cord from the passenger compartment to the battery? I can't seem to find an access area into the passenger compartment to the engine compartment. Any suggestions would be helpful.
  2. N6DZK
    N6DZK Premium Subscriber QRZ Page
    For UHF/VHF or for HF? If it is just for UHF/VHF the power wires to your accessory outlets are plenty beefy (at least they are on the Expedition). Then add a APO between the radio and power. You can get some heavy duty power taps to crimp inline and make a nice neat power tap.
  3. WD8RIT
    I am looking for a direct route to run to the battery as I want to run HF/VHF/UHF.
  4. KN7S
    KN7S Swapmeet Moderator Emeritus Platinum Subscriber QRZ Page
    Not the same vehicle, but my Chevy diesel pickup had virtually every means of access through the firewall filled with insulation. After an hour of probling around I finally went the the rubber gasket surrounding the parking brake cable. A tight fit, but I made it.
  5. N2MOF
    N2MOF Subscriber QRZ Page
    I have a 2013 Explorer, I had to drill a hole thru the firewall and install a grommet. There is no other way to do this, believe me I tried. I am running a Yaesu 857D for over a year now with no problems.
