ad: M2Ant-1
$12 Ham Radio Power Supply
Discussion in 'Amateur Radio News' started by KB1THM, Apr 26, 2020.
  1. KB1THM
    KB1THM Ham Member QRZ Page
    Greater Bridgeport Amateur Radio Club Technical Video:
    Don't like spending a lot of money on ham radio? Do you enjoy projects? Then this video is for you!
    How to convert a server power supply into a 12 volt, 63 amp ham radio switching power supply for about $12 (half the cost of that Baofeng handheld!). Check it out.
    -by Brandon kb1thm
      File size:
      89.3 KB
      802
    K0UO, N4FZ, KG4BFR and 15 others like this.
  2. WQ6N
    WQ6N Ham Member QRZ Page
    I did something similar with a Dell Poweredge 6800 power supply. About 100amp DC.
    It did cost me more than $12. Even though the fan speed is adjustable, it was still put out some fan noise.
    Good for outside. It also needed a dedicated 15amp power input.
    Its all good.
    KB1QHI, N4FZ, KG4BFR and 1 other person like this.
  3. KD5OM
    KD5OM Premium Subscriber
    K3XR, KL5TW, KI4ZUQ and 5 others like this.
  4. WA6LJR
    WA6LJR Ham Member QRZ Page
    I got a Supernight PSU . Fan noise and RF Noisy.
    WA8MEA and KT5OT like this.
  5. KI7HSB
    KI7HSB Ham Member QRZ Page
    Is this going to re-ignite the whole 13.8v vs 12.3v debate?
    K6LPM, WY7RF and N9FC like this.
  6. N4KIN
    N4KIN XML Subscriber QRZ Page
    I have two converted HP units. One does close to 13.8 the other 12.2. I've used both on my FT-857 without issue.
    W1LWT and MW0GYV like this.
  7. KB1THM
    If you want to go bigger there are models that run on 220v like this one made by dell and put out 197 amps @ 12 vdc! Also theres 48v models that people have been using to power LDMOS amplifiers. Currently selling on ebay for $20.
    K0UO, K6LPM and 4F8RS like this.
  8. K4ATR
    K4ATR Premium Subscriber QRZ Page
    would been a good video if he hadn't dropped the F Bomb while trying to connect the power pole!
    there are other models of the HP that is 75 amp on 120v or 100A on 220v and you can modify them to do 13.5 volts.
    K3XR, KA2FIR and 2E0TWD like this.
  9. N6KZW
    N6KZW Ham Member QRZ Page
    so the resistor I used was 1k . giving me 13.98 volts... anybody know how much deviation from 1K to get 13.4ish?
  10. KI7HSB
    The value of the resistor does not control the level of the output voltage. It is just a signal in to allow the power supply to turn on.
    There needs to be a resistor of a specific range because the analog level of the voltage into that pin (PSOK) will determine one of three states, one of which is 'Power Supply Fault' which will cause the unit to shut down.
  11. M0FEU
    M0FEU Ham Member QRZ Page
    I seem to remember reading elsewhere that lack of RX noise is only half the story. Depending on the switching frequency, you could get spurious harmonics on TX. What with the explosion in buck/boost converters (some quiet, some not so quiet), some content showing how to create effective filters for these things would be extremely helpful.
    73 de OE6FEG/M0FEU
    Matt
    KA2FIR, WA8MEA and KI7HSB like this.
  12. N9FC
    N9FC Platinum Subscriber Platinum Subscriber QRZ Page
    What do you modify to get them to do 13.5 volts. I'd prefer my power supplies to be as close to 13.8 as possible. If it's a simple mod I may pick up a few of these.
  13. KM4ZZ
    KM4ZZ Premium Subscriber QRZ Page
    Looks very interesting, and you can't beat the price. I have ordered one to play with, but I can't find any documentation online for them. Some of you seem to know more about them. Where can I learn more? Modification for 13.8 volts would be cool. I doubt there is a trimmer pot inside to set the voltage, but you never know.
  14. KD8GZE
    KD8GZE Ham Member QRZ Page
    At least for the supplies that I have experimented on, such as the HP DPS-600PB, a resistor is connected to the power supply pins to "trick" it into thinking it is delivering a lower voltage at the other end of the wiring harness. In this way the supply produces a higher voltage to compensate for it. I think the correct term might be a "sense line".
    A key thing to note is that different supplies have varying amounts of tolerance for how much beyond the rated 12 volts you can go. One of mine would happily go closer to 13.8 V, while others trip due to over-voltage protection around 12.7 V.
    Here are some handy links:
    Repurposing server power supplies:
    https://www.rcgroups.com/forums/sho...high-quality-12Volt-100Amp-Power-Supply-Part1
    Pinout of the aforementioned DPS 600PB:
    https://static.rcgroups.net/forums/attachments/4/2/3/3/7/0/a8495561-247-DPS-600PB PINOUT.gif
    Source for nice adapters for common server supplies:
    https://www.parallelminer.com/product-category/power-accessories/server-power-supply/
  15. N3VMM
    N3VMM Ham Member QRZ Page
    Came across a different type. Not sure if it would work. I might have to purchase one to try.
    HP 1200W G6 HOT-PLUG POWER SUPPLY. Did a search on Ebay and Amazon. Prices differ. $35 and ubove on Ebay and $25 and above on Amazon. Checking on a video about these, will see what they say.
ad: CQMM-1
