ad: M2Ant-1
10 Meter Quad Project
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KD5PIV, Aug 2, 2009.
  1. KD5PIV
    KD5PIV Guest
    Has anyone seen a good 10 Meter Quad antenna project. I'd like to get a little direction to my 10 meter contacts which I now make off a vertical.
    73 Steve
  2. VE3PP
    VE3PP XML Subscriber QRZ Page
    When you are driving around watch for 11 Meter PDLII Quads on towers. If you see one, stop and ask if the owner is still using it. If it is not in use and you can get your hands on it then you have all the parts for your 10 meter quad.
    If not then it is easy to build one if you want to buy the aluminum tubing to support the fiberglass spreaders.
    Of course you need to buy the spreaders too.
    Do a Google Search for "QUAD ANTENNAS" and you will find lots of info including a site that allows you to put the frequency in and then it calculates the spreader length, wire length etc.
  3. K7NNO
    K7NNO Moderator QRZ Page
    The last 10m quad I built I used 3/4in PVC and an aluminum boom. It was extremely cheap as I used 2 hole conduit straps to hold the spreaders on. I worked over 100 countries with it using an Armstrong rotor.
ad: UR5CDX-1
