1:1 - 1:2 or 1:4 heavy-duty Balun 2kW
Discussion in 'Ham Made Gear' started by DL1GME, Oct 9, 2017.
  1. DL1GME
    DL1GME Ham Member QRZ Page
    You need a new, heavy-duty 2 kW Teflon current balun to build dipoles, center fed antennas, DeltaLoops or even ground planes? Here it is... :)
    The balun consists of two 60 ferrite cores as well as heavy-duty Teflon line.
    The cores are cast in epoxy resin and mounted weatherproof.
    Standing waves are suppressed by this type balun with about 30dB.
    All screws are made of stainless steel - V4A.
    All exterior washers and the SO-239 connector are sealed with sanitary silicone.
    The housing has two internal ventilation holes on the back.
    A turning the SO-239 connector is excluded by the 4-hole flange.
    Impedance: 50 Ohm
    Frequency range: 1.6 to 52 MHz
    SWR: better 1.2
    Standing waves stop band attenuation: 30 dB (at 14 MHz)
    Insertion loss: less than 0.1 dB
    Powerrating: 2kW (!!!)
    Weight: about 650 grams
    Dimensions (in mm): 115 x 90 x 56
    Including measurement log.
    Feel free to ask for other Balun-types...
    DL1GME - N.Melo
  2. K2LED
    K2LED XML Subscriber QRZ Page
    Please post pricing. 73
  3. DL1GME
    Hi there,
    it depends on the type of Balun.
    A simple 1 kW 1:1 / 1:4 Balun costs 59 Euro.
    The 2 kW 1:1 / 1:4 Balun above (2 ferrit-cores) costs 79 Euro.
    Prices + shipping via DHL with tracking-ID-number.
    best 73 de DL1GME - Nelson Melo
  4. GM0PHW
    GM0PHW Premium Subscriber QRZ Page
    hI,
    Cost for 2Kw version including Shipping to Scotland UK
  5. DL1GME
    Hi there,
    costs for shipping to Scotland UK via DHL with tracking-number and insurance 16 Euro.
    So, 2kW 1:1 or 1:4 version costs at all 95 Euro.
    Best regards DL1GME - Nelson Melo.
  6. GM0PHW
    Received today, very please with the construction and materials used, very professional.
    Thanks Nelson.
    Mike gm0phw
  7. 4Z5UY
    4Z5UY Premium Subscriber QRZ Page
    Hi Nelson
    Sorry it took me so long to say you thank you here.
    I use the Balun almost every day with pleasure and I couldn't think of a more professionally made one.
    Thanks 73 de Uriah 4Z5UY
  8. DL1GME
    No Problem. Sometimes it took some more time to find out, what the difference is :)
    All the best Uriah :)
