The FCC has responded to the ARRL's petition to retire the 300 baud symbol rate restriction on HF. The full document is available on the FCC ECFS. The highlights: Comments can be made through the FCC's ECFS system, referencing RM-11708. Remember, effective comments are polite, focused, and devoid of personal attacks or conspiracy theories.
It is just a matter of whether Ham Radio will help to lead this technological revolution, keep up with it, or be dragged kicking and screaming into the RF techniques of the 21st century. There is already the long-existing rule: 'hams must use the minimum bandwidth necessary' for communications. That rule is still in effect and will not be changed by this FCC rulemaking. Finite bandwidth limits such as 2.8 kHz or 3.0 kHz are counterproductive to technological innovation. FCC RULE: §97.307 Emission standards. (a) No amateur station transmission shall occupy more bandwidth than necessary for the information rate and emission type being transmitted, in accordance with good amateur practice. With the trend toward very fast communications that can contain a lot of message, with a short time spectrum footprint, it could lead to even better sharing than the antiquated frequency-based separation of the 20th century model. The HF bands are not always crowded... for example: We are in the bottom of the solar cycle, and it is night here. I'm tuning around 15 meters right now and there's not a signal I can copy here. Would it bother anyone if I used the whole digi sub-band segment at 100 watts for 10 seconds to send an emcomm spreadsheet message on groundwave to a station 20 miles away? No. Beginning in the 1980's, as a cellphone design engineer, I watched the evolution of cellular phone technology... we once used conventional FM for it. It evolved, and now we use various forms of Time-Division, Code-Division, and combinations of various time-interval modes. That innovation has vastly increased the number of signals that share the same spectrum. The same revolution is happening in a similar way to HF, for commercial and governmental radio services outside the ham bands; and it will eventually happen to hams on HF. FCC concluded that the antiquated symbol rate rule should be eliminated. FCC also concluded there should be no new finite bandwidth limitations. I fully agree with FCC's conclusions. We need to support FCC's "no finite bandwidth limit" because it keeps Ham Radio open to development of new radio techniques and systems. On the horizon, we can now see some of those new radio techniques which looked nearly impossible to implement 25 years ago.
Yes. Too many hams treat these comments on NPRMs as a "vote" for or against. That is not what the comments are for. The FCC asked that commenters address five specific questions: 12. While we tentatively conclude that a specific bandwidth limitation for RTTY and data emissions in the MF/HF bands is not necessary, we nonetheless request comment on ... * ... whether we should establish emission bandwidth standards for amateur service MF/HF RTTY and data emissions. * ... Commenters favoring such action should address what the maximum bandwidth should be, ... * ... the basis for the particular limitation the commenter proposes, .... * .... and whether the limit should apply across the bands or only in particular subbands. ... * ... Commenters should explain the grounds for departing from the generally applicable standards.
