ad: portazero-1
New DigiMode — ROS. 1st QSO this evening.
Discussion in 'Amateur Radio News' started by GM4BRB, Feb 19, 2010.
  1. GM4BRB
    GM4BRB Ham Member QRZ Page
    Recorded at University of Twente (Netherlands) Web SDR:
    http://websdr.ewi.utwente.nl:8901/
    2205z ROS: PA3FWM, one hour ago has place the first offcial QSO with ROS, and it was received at this SDR. Thank you
    2205z PA3FWM: Ah, I had seen your repeated advertisements for your experiment, so it's nice to know that it worked out!
    2206z ROS: It was a historical moment. It was on 7065 LSB
    The First QSO
    18 February 2010, at 20:56 UTC took place the First Official QSO with ROS from Vitoria (Spain) to University of Twente (Netherlands) covering a distance of 1265 Km. on 7.065 Mhz. The first Ham Radio Operator to get it was EA2LE.
    The First Automatic Reply
    ROS notification: EATEST has received your Radio Message
    ********** Please don’t reply to this email ********************
    EATEST has received your Radio Message sent at: 21:03 UTC
    Received Message: ‘CQ CQ CQ de EA2LE EA2LE EA2LE pse k My email is: <ea2le@ure.es> <ea2le@ure.es> <ea2le@ure.es>’
    Operator Info:
    Callsign: EATEST
    Name: Jose Alberto Nieto Ros
    E-mail: nietoros@hotmail.com
    QTH: La Aljorra-Cartagena SPAIN
    Locator: IM97lq
    Station: web SDR
    ROS Version: 1.6.1 beta
    Signal Info:
    Symbol Rate: 16 bauds
    Frame Acquisition: 20/20
    Final Acquisition: 15/16
    Frequency Shift: -39,1 Hz
    Symbol Errors detected by Viterbi: 2/50
    Metric: 0 dB
    Vumeter Level: -8 dB
    CPU Usage: 20 %
    Download the ROS beta Software and give it a try, sounds cool.
    http://rosmodem.wordpress.com/
    Requires WinRaR or similar Rar unzipper.
  2. K4NIN
    K4NIN Ham Member QRZ Page
    So, can we use this in the US? Is it legal here? Frequencies?
    Sounds fun..
  3. AD7N
    AD7N Ham Member QRZ Page
    It's completely dependent on bandwidth.
    I've dug some and can't find the bandwidth of this thing. :confused::confused::confused:
  4. AD7N
    Yes! According to the comments on his site:
    This thing has an S/N of -35dB @ 1baud, I think that's a new record!
    WSPR is around –28-30dB!
  5. N9DSJ
    N9DSJ Ham Member QRZ Page
    Any evidence of this, even anecdotal? EME ops will be all over it if true...
    Bill N9DSJ
  6. VE3TEF
    VE3TEF Ham Member QRZ Page
    receiver online
    My receiver is online tonite to see if there is anything on 7056. Looks like and interesting mode!
  7. AD7N
    I have pretty good evidence: For starters, if you use the supplied WAV file on the website (labeled as a test sample of -35 dB S/N), you get -35dB S/N. This noise has fairly high peaks and some good troughs.
    I've been playing with Audacity and playing recording of the mode and noise at the same time, and I've gotten at least -31dB with fairly reliable copy. I used the white noise generator in Audacity, and read the "Metric" scale in ROS. Audacity's "white noise" is a worse-case scenario - absolutely NO nulls or peaks. I would say -31dB in this scenario is pretty darn good, considering real-life noise will wax and wain over time.
    -31dB is beyond WSPR mode, and ROS is real-time, whereas WSPR requires ~2 minutes to decode before you can read it.
  8. BA4TB
    BA4TB Guest
    The download web page is blocked here,could anybody setup a mirror site for downloading?
    thank you!
  9. K2WH
    K2WH Platinum Subscriber Platinum Subscriber Life Member QRZ Page
    msg deleted by me.
  10. K2WH
    My Norton Utility stopped ROS dead in its tracks. Msg received from Norton was ROS is a security risk. Installation was terminated and Norton deleted the program.
    K2WH
  11. K4AX
    K4AX XML Subscriber QRZ Page
    norton would label me a Virus if it could..
    NOD32 is the best thing going for such, and won't raise as many false flags.
  12. K2WH
    Rarely (this may be the first time) Norton has ever flagged a download. So, I will go with Norton for now. I will check out this NOD32 (Never heard of it).
    K2WH
  13. K4AX
    Gotchya, it may or may not be a false positive. I think developers many times have to contact Norton to get it squared away. Do a google search for norton and false positives.
  14. NF0A
    NF0A Ham Member QRZ Page
    Will not work on Windows Vista/
    Nor Windows 7...
    No dowmload problems at all...
    XP ok...
    NOT a security risk despite stated here...
  15. NF0A
    Norton, in general; Sucks....
    AVG believe it or not,Better...
