Quote:
Originally Posted by KC8CDQ
I don't have a static IP. Using DynDNS that is one of the choices they have when using their service.
I don't want to be a kill joy, but if you are using DynDNS because you are running your web server out of your home, then be careful. Operating a web server out of your home is "ok" if you are hosting just your site, and your site only. Then you are still at risk at best.
Under most ISP terms and conditions it states that you can't run a web server off of their home service agreement. If you want to host multiple web sites they require you to purchase a business package.
Like I said if you are running a personal site, they will usually overlook it, but if you are hosting sites for 20+ Amateur Radio operators, they are going to shut off your service and require you to get a business class plan ($$).
I just wanted to give you a heads up before a lot of hams are left in the dark with no access to their site.
You may be fine for a while, but when your ISP does a port scan, which they do occasionally, they will find your web server responding to the request. (As well as your FTP server. Which is a violation as well.)
Just 2 pennies thrown in a deep well.
