QRZ Forums   QRZ Ad 1075
 Forum Home   QRZ Home
QRZ Ad 55
QRZ Ad 1496
QRZ Ad 2038
QRZ Ad 1994
QRZ Ad 1440
Google Search
QRZ Web
Do you find QRZ helpful?
We appreciate your support.
Go Back   QRZ Forums > Online Swapmeet > Ham Radio Gear For Sale
Reply
Thread Tools Display Modes
  #1
Old 11-08-2009, 12:11 PM
W8EK W8EK is online now
Ham Member
Smile Wattmeter/SWR, Baluns, Speaker, Mics, HT Accessories, filters
Extensive List of Many Ham Items For Sale
Wattmeter, Baluns, Speaker, Microphones, HT accessories,
Filters, Phone Patches, Keyer, and much more
Wattmeter and SWR Bridge:
Heath HM-2102 VHF wattmeter, covering 50 to 160 MHz.
Similar to the HM-102, but for VHF frequencies, with
250 and 25 watt scales. It can also be used to check SWR,
and has a remote sensor that can either be left inside
the meter, or separated from the actual meter by about
3 feet. SO-239 connectors in and out.
This particular meter works great, looks fine and includes
paper work for $ 40.
Heath HM-15 SWR Bridge
It is an HF SWR Bridge, with SO-239 connectors on the back.
The front has the meter on the left, and two knobs to the
right. It is the same size as the HD-15 phone patch. This
one works fine and is in nice cosmetic shape. Paper work
included for $20.
HF 1 to 1 Antenna Baluns:
A balun is made to convert the unbalanced coaxial cable to a
balanced antenna, such as a beam or dipole.
These are all 1:1 baluns, which means that they will preserve
the impedance, instead of acting like a transformer. They will
handle full legal power, and take a PL-259 connector.
Bencher ZA-1 A Balun
This 1:1 balun will handle full legal power, and can be used
either with a dipole or a beam. It has strain relief for the
dipole wire, and can be hung from the provided mounting hole.
This one works fine and looks great. $40.
The Big Signal W2DU Balun
Model HF. 1 to 1 ratio. Stainless steel hardware.
A lightning arrester is included in this balun.
It is a current type balun, covering from 1.8 to 30 MHz.
This one works fine and looks very close to new. $25
Hi-Q Balun by VanGorden
This balun has a 1 to 1 ratio, and also includes a
lightning arrester built in to it. It also is for HF,
and can function as an antenna center insulator as well.
This one is still in its original packaging. $20
Coax Cable with Type "N" Connectors
This cable is made of RG-8 coax and is about 6 feet long.
It has a male type "N" connector on each end. $15
Kenwood Log Book
Completely unused, new condition. It has standard log
book pages, with a world map on the inside cover, and
a DXCC list (as of 1987) in the back. Cover is a
silver color with the Kenwood Logo. $8
World Map with Kenwood Logo
This map is laminated, and lists DXCC Countries, as
of 1985. Obviously, it is not completely up to date,
but still is a very nice map. Like new. $5
Kenwood MB-4000 Mobile Bracket
This mobile bracket is made to be used with the Kenwood
TW-4000 dual band transceiver, and possibly other rigs
as well.
This one is in good shape, with the paper work and hardware.
$15
Communications Speaker
This 4 inch square speaker is optimized for communications
frequencies (300 to 3000 Hz). It is a Realistic Radio Shack
speaker in a black enclosure, and is an 8 ohm speaker. It
has a cord with a 1/8 inch (3.5 mm) mono plug on the end.
This one works fine and looks OK also. $15
Microphones:
Yaesu MH-31 B 8 dynamic hand microphone
This is the Yaesu hand microphone that has the round
8 pin connector on it. It will go with virtually any Yaesu
rig that uses the round 8 pin connector. It has up, down,
and fst switches, and well as a tone switch, in addition
to the PTT switch. This is a modern MH-1 B 8 mic.
This particular unit works 100%, and is still unused in
its original box. It even includes the new shiny, chrome
mic holder for $40.
Icom HM-7 Hand Microphone
This low impedance dynamic hand microphone has an internal
preamp in it, and is used with Icom rigs such as the 245,
260, 290, 451, 490, 505, 560, 720, 730, 740, 22U, 25A, 251A,
and maybe others. It has a 4 pin plug on it.
This one works fine, and looks like it just came out of
the box. $30
Generic Hand Microphone
This is a low impedance hand microphone, black in color.
It is presently has an 8 pin round connector, wired for
Kenwood. $25
As above, with no connector. $22
Regular hand microphone
Electret Condenser microphone
Generic Black mic, with gray PTT bar. Requires polarizing
voltage. $25
Lafayette EAM-15 dynamic hand microphone
2000 ohm impedance can be used any place a dynamic mic is needed.
Stripped and tinned leads.
It works fine, and looks good also. $25
DTMF Touch Tone Microphones:
CES 600 L, Universal DTMF microphone
This has a normal touch tone pad on the front, with
a low impedance microphone. This one has the 8 pin
modular plug (like a computer LAN) on it. This mic has
not been used, so it is in really great condition.
With paper work for $40.
Data Signal "Data-Coder 5" touch tone mic
This mic has a 12 digit touchtone pad on it, plus a
normal low impedance microphone. With 4 pin plug.
Like new. $38
Two meter FM Transceiver:
KDK FM-2033 mobile FM transceiver for 2 meters
This rig produces just over 25 Watts in high power and
about 7 watts in low power. The rig is fully synthesized,
has memories, scan, subaudible PL tone, and all the things
that one expects in a 2 meter rig. It has a touchtone
microphone with it. It sounds great, and hears well.
It needs 13 V DC at about 7 amps.
This particular rig is in very nice condition. There is
one paint spot missing, about the size of a pin head. It
includes the touchtone microphone, mobile mounting bracket,
power cord, and paper work. The original box is also included,
although the box looks much worse than the radio. Even the
mic clip, and a bag of screws are included, as is the
original multicolored sales brochure. $89
Speaker Microphones:
Yaesu MH-34 b 4 b speaker microphone
This is the one that fits the Yaesu VX-8, VX-7, VX-6,
VX-5, VX-3, VX-2, VX-1, and that series of HTs. I think
it also fits the FT-50 and FT-60, and maybe others. It
has a single 4 conductor, 3.5 mm plug on it. This one
is just like new. $30
Kenwood SMC-24 speaker microphone
Fits Kenwood TR-2400 HT and others. This one looks
fine and works fine. $18
Other HT accessories:
Lithium battery for Yaesu VX-2 or VX-3 HTs
Spare Lithium Ion battery pack for Yaesu VX-2 or VX-3.
It fits the new VX-3, as well as the earlier VX-2.
1200 mahr capacity. It holds a charge fine, and is
basically new. $20
Kenwood SC-13 Vinyl Case
For TH-215, TH-225 and others, with room for the larger PB-1
and PB-4 battery packs. It can also be used with the smaller
PB-2 and PB-3 battery packs, by putting a filler in the case.
Black color. In very nice condition. $15
Bianchi Real Leather Case for TH-215, TH-225, etc.
For use with the larger PB-1 and PB-4 batteries, but can be
used with the smaller PB-2 and PB-3 batteries. This is real
leather, tan in color, and is in very nice condition. $25
Case for Drake TR-33C
This is the black case that fits the Drake TR-33C, and has
cutouts in the back for antenna, power, etc. It includes
the shoulder strap, and is in good shape. $12
Case for Drake TR-22
As above, but for the TR-22. No shoulder strap. $10
Belt Clips:
All include the hardware with the belt clip and are $8 each.
Kenwood TR-2400
Motorola
Yaesu FT-207
Yaesu FT-209
Wrist Straps for various HTs - $4 each
Kenwood TR-2400
Yaesu FT-209
Rubber Duck antennas for your HT.
All are for 2 meters, are in good condition,
and are $10 each, unless stated otherwise.
5/16 inch threaded, like used by Motorola and others
Regular - 5.7 inches long
Stubby - 4 inches long
Type F connector - 6.5 inches long
PL-259 connector - 6.5 inches long
HyGain 275, still in original packaging
PL-259 connector - Stubby - 4.6 inches long
Centurion, still in original package
Special for Kenwood TH-21 HT threaded connector
Kenwood RA-6 regular, 6.6 inches long - $15
Kenwood Stubby Duck for TH-21, 4 inches long - $15
Alinco Stubby w/BNC Connector, 4.6 inches long
BNC Stubby for 440 MHz, 3 inches long
Battery charge adapter for Azden PCS-300 HT
This is an adapter that permits one to charge the battery
of the Azden PCS-300, 2 meter HT, outside of the HT itself.
Usually, one must have the battery inside the HT, but this
lets you charge a second battery outside of the HT. The
original charger is used. If you have a PCS-300 HT, you
need this adapter.
It works fine, and looks like new. $3
TenTec items:
"Switcher / 25" 25 amp switching power supply
This is a 25 amp switching power supply in a case that
matches the early Omni series case, with the metal bezel
around it. It is in a case that is the same size as a 243
remote VFO. It has an ammeter on the front, along with
Switch, TenTec logo, and output bulb. The front panel
basically looks like a 280 power supply with a metal bezel,
but says "Switcher/25" on it. It is very quiet, and well
shielded, and does not produce any electrical noise that
I could find. $150
Hustler HF mobile resonators:
All work fine and are in great cosmetic condition.
Regular (400 Watt PEP) Resonator:
40 meter, RM-40 $17
"Super" high power resonators (good for 2 KW PEP)
15 meter RM-15 S $18
10 meter RM-10 S $16
Coax Cable with Type "N" Connectors For Sale:
AEA Items:
AEA AC-1
"Wall wort" 12 V DC power supply at 1 amp.
Can be used with PK-232, PK-88 or others. $15
Phone Patches:
Waters "Universal Hybrid Coupler II" Model 3002
Most of us would likely call this a phone patch, but it
is really much more than that. It does that, but also
will interface with a tape recorder, and permit recording
and play back of on-the-air QSOs. Nothing says that the
tape recorder input must be used that way. Connect the
sound card in your computer in this position, and you
have a very effective interface.
Model 3002 includes a speech compressor powered by a 9
volt battery. The front panel is finished on both
sides, with one side having it set in a horizontal
position, and the other in a vertical position.
This was a "top of the line" unit years ago. One only
found them with top stations such as Collins.
This particular unit is in really great condition.
With paper work for $100.
Heath HD-19 Phone Patch
This phone patch is made to match the Apache, Marauder,
etc. The large VU meter is in the middle. Below the
meter is a single conductor mic jack, two small chrome
knobs for xmtr and rcvr gain control, and a larger rotary
on-off switch with chrome knob on the right. There is a
terminal strip on the back for connections. Of course
it can be used as an interface to sound cards for digital
mode operation as well.
This unit looks extremely nice. Of course it works fine.
With paper work for $25.
CW Items:
Palomar Engineers IC Keyer
This keyer includes a sidetone with speaker built in. It
also will operate in either full automatic mode (like most
keyers), or in semiautomatic mode (like a bug). The 9 Volt
battery is external, so it can be changed easily. This one
works great. $45
Cables for CW Straight Key and for CW Paddles:
Cable for straight key
About 3 feet long, with a mono 1/4 inch phone plug on it,
as is used with a straight key. $5
As above, but 1/8 inch (3.5 mm) plug. $5
Cable for paddles
About 3 feet long, and with a 1/4 inch stereo connector
on the end, like used by most rigs. $8
As above, but 1/8 inch (3.5 mm) plug $8
Low Pass TVI Filters:
A low pass TVI filter is added to the transmitter (inserted
in the coax line after the transmitter or transceiver) to
reduce harmonic interference.
Drake TV-3300-LP Low Pass Filter
This is a modern low pass filter to go between your transmitter
and antenna, and has been optimized to have more attenuation
in the 40 MHz region, where many TVs have their IF. It is good
for 1000 Watts "average" according to the manual, and has
over 80 db attenuation at 41 MHz. This one looks great, and
includes the paper work. $30
B & W FL-10/1500 (Formerly known as model 425) low pass filter
B & W TVI filter, 50 ohm. It cuts off just above 10 meters,
and will handle 1500 Watts. SO-239 connector on each
end. This is the latest model B & W filter. It is in very nice
condition; it looks very close to new. With paper work $40.
Bud LF-601 low pass filter
This filter is adjustable for best attenuation in your particular
situation, and also to more closely match your specific impedance.
It cuts off at about 52 MHz (if adjusted as such) so it can be
used on 6 meters, and will handle 1500 watts.
In extremely nice condition for $35.
Coax connectors and adapters:
Prices are per connector. Several of each are available.
These are NOS (have not been used).
BNC male
standard type - $2
crimp on type - $3
Chassis mount BNC female square mount (uses 4 screws) - $3
screw in type - $4
BNC 90 degree - female to male - $3
BNC "T" - two female and one male - $4
Antenna adapter to fit the BNC connector on the HT
and provide an SO-239 connector that will permit
a PL-259 to be attached. (BNC male to UHF female) $5
UHF Male (PL-259) to BNC female (opposite of above) $5
UHF double female "Barrel connector" (two SO-239 together) $3
Chassis Mount SO-239 connectors (square) $1
UHF "T" connector with two female (SO-239) and one male
(PL-259) connection - $5
UHF female (SO-239) to type "F" Male (as used on cable TV) $5
Type "F" (cable TV) female to BNC male - $5
LARGE Analog Meters:
General Electric Edgewise DC ammeter
0-100 ma scale - Edgewise meter with scale 5+ inches
long and 1.7 inches high. White scale, w/ silver/gray mounting
This is a very nice meter that can be read across the room. $30
LabVolt AC ammeter
0-1 amp scale, 4 inch square meter, $20
LabVolt DC ammeter
DC voltmeter has 3 scales on it - 5, 10, and 25 volts.
It says it is a Niehoff Voltmeter, Chicago, Model T-2.
It looks like 1930s vintage, and is in very nice shape. $28
Very heavy duty chokes, as used to filter ripple in high current
power supplies.
These chokes (inductors) weigh about 8 pounds each, and
are designed to be used in low voltage applications. They were both
removed from power supplies, and are in close to new condition.
One is from a 20 amp power supply. $13.
Another is from a 30 amp power supply. $15.
Prices do not include shipping from Florida.
Thanks.
Ken, W8EK
Ken Simpson
E-mail to W8EK@FLHam.net or W8EK@arrl.net
Voice Phone (352) 732-8400
Notice: Due to a high number of swapmeet listings, I have
been asked by QRZ to provide the following notification:
My swapmeet sales on QRZ are not-for-profit. As a service to
my friends and acquaintances, I help them and/or their survivors
dispose of equipment that is no longer needed. Because I realize
the difficulty relatives have disposing of equipment after one
becomes a silent key, I have decided to "thin the herd" of much
of my own 40+ year accumulation of equipment. This is not a
business venture for me, and I am not in the amateur radio
business.
W8EK@FLHam.net / W8EK@arrl.net
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 1995-2008 QRZ.COM
