QRZ Forums   QRZ Ad 42
 Forum Home   QRZ Home
QRZ Ad 1994
QRZ Ad 1440
QRZ Ad 55
QRZ Ad 1496
QRZ Ad 1997
Google Search
QRZ Web
Do you find QRZ helpful?
We appreciate your support.
Go Back   QRZ Forums > Ham Radio Tech > Questions and Answers
Reply
Thread Tools Display Modes
  #1
Old 11-08-2009, 12:32 AM
VK4NWH VK4NWH is online now
Ham Member
Default MIRAGE B215 vhf amp help
, I am looking for a manual for a b215 vhf amp, does anyone have a manual that they can copy and email or post? I will pay any costs involved. Mine is a 1985 model 2 watts in and 150 watts out. Mirage have nothing at all. My amp has 50 watts fm and nothing ssb but was working fine till something went off track. Any ideas or help is greatful. Thanks.
Wayne VK4NWH
amateur_radio@westnet.com
__________________
vk4nwh@yahoo.com
  #2
Old 11-08-2009, 12:37 AM
KC8VWM's Avatar
KC8VWM KC8VWM is online now
Ham Member
Check the switches, relay circuits, measure all resistor values (may be an open resistor) Some of these amplifiers have built in shut down protection circuitry which may have gone awry. Measure the voltages present on the power transistors and instead of using a schematic, download a spec sheet for the output transistors in question and compare the spec sheet voltage information with your readings. Rule out if it's the power transitors at fault or if the other circuits supplying current to the output transitors are at fault etc..
Also be sure to check the obvious but not so obvious things like coax connections, (especially the ground side of things) broken or loose switch wiring, be suspicious of brown marks or solder corrosion occuring on the circuit board etc..
Good luck
__________________
73 de Charles - KC8VWM
  #3
KE7TBB's Avatar
KE7TBB KE7TBB is online now
Ham Member
Default manual
www.mirageamp.com/man/pdf/B-215-G.pdf
your welcome
just a google search brought it up
__________________
Gun control is hitting your target
  #4
Old 11-08-2009, 01:41 AM
WB2WIK WB2WIK is online now
Ham Member
Quote:
your welcome
Didn't work.
  #5
Old 11-08-2009, 01:57 AM
Ham Member
Default not the G model
thanks WB2WIK and KE7TBB i seen that but thats the G model mine is the 1985 b215 not b215-G but thanks for ur help.
__________________
vk4nwh@yahoo.com
  #6
Old 11-08-2009, 02:00 AM
Ham Member
Thanks Charles KC8VWM i did check the output transistors and had voltage to them all but ill check again and also so through your thoughts also. it worked fine while i was txing and i turned it off to compare signals with other hams and when i turned it on again ... nothing. But ill start again with your ideas. i already replaced the mps-a13 switching transistors.
__________________
vk4nwh@yahoo.com
  #7
Old 11-08-2009, 02:26 AM
N6OSB's Avatar
N6OSB N6OSB is online now
Ham Member
Try this link:
http://www.mirageamp.com/man/pdf/B-215-G.pdf
__________________
SKCC #: 5299
  #8
Old 11-08-2009, 02:48 AM
Ham Member
i seen that but thats the G model mine is the 1985 b215 not b215-G but thanks for ur help. cheers.
__________________
vk4nwh@yahoo.com
  #9
Old 11-08-2009, 03:03 AM
KC8VWM's Avatar
Ham Member
It's just another thought but you indicated it makes power on FM but not on SSB. This suggests the RF sensing circuitry is probably working (switching to TX, ok) however, I am still somewhat curious if connecting an external switch and try TX'ing the amp with an external keyer will somehow produce different results?
Also thinking that while FM is present on output but no SSB operation may suggest a voltage issue in the output transistors bias supply circuit? But like yourself, I'm not looking at a schematic either. I would probably start by measuring resistor values in proximity to the transistors to see if one has opened somewhere. Keep in mind although you have the correct voltages powering the power transistors, there is still a chance one was fried. I have to admit though, I'm kind of surprised the fuse didn't open in the process. Not sure what type or transistors they are exactly but it may be possible to measure continuity or resistance from them using a VOM and compare the readings of each transistor against one other for the purpose of conducting a comparative analysis. One transistor may read differently than all the others scenario. Perhaps you had a power spike of some sort?
I realize this is sort of a shotgun approach, but i'll keep thinking and I'm sure others will chime in with their own thoughts. Maybe someone will even post a good schematic so we can all sit on here and have a good gawk at it.
My Best,
__________________
  #10
Old 11-08-2009, 03:57 AM
Ham Member
well charles im living in hope at the moment but your ideas are certainly some good points to start looking at.
__________________
vk4nwh@yahoo.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 1995-2008 QRZ.COM
