K1FO is Steve Powlishen, who founded Lunar Link Systems
http://home.cshore.com/lunarlink/info.html
and they make a 2-meter amplfier that uses the popular triode tube, 3CX800A7
http://home.cshore.com/lunarlink/la-x2A_data1.pdf
Steve, K1FO (then WA1FFO) first 2 meter kW amplifier was built in 1971 and
he used the classic push pull 4CX250 tube design.
Steve, WIK is grinning about now.
Quote:
The 2 options open to me are either GU-74b (4CX800) or GI-7BT
Trevor -
OK, here are some of the pros and cons (hopefully Steve, WIK and Randy, W2VW will add to list!)
The GU74b is a Tetrode and the GT-7BT is a Triode tube
Tetrodes, IMHO, require a bit more TLC from the amplfier's power supply and control circuits -- hopefully that is addressed in the amplifier's microcontroller.
The Svetlana 4CX800A is manufactured in the "Svetlana Electron Devices" (SED) factory in St. Petersburg, Russia. The tubes current being sold by QRO tubes for $199 rach (Soviet marked as GU74B) were made in the USSR from 1980-92 at the Svetlana factory.
As you have commented, there have been many conversions lately about availability of many ceramic RF tubes. Some manufacturers even delayed or canceled production of amplifier models due to sources for RF tubes.
The GI-7BT is a surplus Triode tube used by the Soviet military.
While there is a LARGE surplus of these tubes currently, I have not seen anyone currently producing this tube.
I noted that the amplifier that used 2 - GI-7b tubes, listed an alternative tube.
